Heavy Duty Inner Tubes
Matthew
Hi All,
Anyone know a good supplier of heavy duty inner tubes?
I need some 155/165-14 tubes for staun beadlocks, and as a back up I need some tubes for a set of 34x1050x16 Simex Jungle Trekkers, but don't know what size these need to be?
Thanks,
matt
Can you use innertubes with Stauns?? I would have thought because of their "innet tube" style pneumatic design they would be a serious conflict of interests going on possibly causing chafing and punctures at low pressures.
For Staun innertubes speak to Paul at Challenger 4x4 he did mine a treat for me,
I cannot see how a Staun and a seperate innertube can work together, beside the chaffing why would you want a tube when you've got a beadlock?
Landranger services (who advertise) managed to get me a set of thick Landrover'ish tubes for a reasonable price, but a good mate told me he had previously bought some from a tyre specialist at £25 a go. not so cheap!
Thanks for the comments, I'll try challenger again, tried them before but they didn't keep them in stock.
Just to be clear, I don't want to run stauns AND tubes in the simex's - stauns are pretty difficult to fit without pinching the tubes, so I wanted some large tubes as a back up for the weekend encase I can't get the stauns set up properley.
matt
Matt,
Don't be a tart, skin the back of your hands with the Staun's, and get em fitted. :huh:
Staun's are not "pretty difficult to fit", they're effin difficult to fit, I did 5 in a day on a tyre machine and suffered with sore handies for a couple of days. :(
Best of luck :D
Matt,
Best of luck :D
Hi Boothy,
Your definitely right there! we started with 4 tubes, managed to get 2 wheels fully built up, but the other 2 tubes we pinched and they then burst upon inflation! These beadlocks (as you know i'm sure) are fantastic when they are up and running, but my god are the a pain to put together!!!!
My hands have until saturday to recover!
matt
Darling, it's lovely to hear of you,
I run my tyres at 12psi and my Stauns at 60psi,
I'm not cutting my Mach5's up just yet when the Stauns are still doing a good job but, who know's?
Saleys just done his own double bead locks and I think they're bludy good, wheel see. :rolleyes: sorry
Have you ever run your tyes lower at say 6-7 psi??? want to know how they performed.
I saw Saleys at the weekend, they looked the part, and worked to.
I run 2 stauns and 2 clamped outer rim bead locks.
For slower off road use I would highly recomend rim bead locks.
If you only ocasionaly / never need the bead lock ability but are regularly on the road I would recomend staun type bead lock.
I found dirt/grass/twigs can still push inbetween the tyre and rim on Staun, a inflated 60psi tube moves inwards when you are giving them abuse the tyre then goes flat as if you had a slow puncture
This is bearable at a compatition but irritating the following day.
I allso like the confidence of an extreemly strong outer wheel rim when you have the weld on type outer rim bead lock.
I run my tyres at bellow 5 psi during comp.
I've got dumper tubes with water valves in my mach 5's and I have no problems with punctures at very low pressures.
They don't look to bad either... :rolleyes:
Hi Gents,
Nige, thanks for the sizes!
Smo, the Staun Beadlocks use a 155/165-14 tube to lock the beads onto the rim, then you don't use a tube in the normal tyre. see below... (how is the D-Lander coming on??)
matt
Ah yes but the staun inner tube is kevlar reinforced and in a kevlar bag or somthing from memory to make it super strong.
D-Lander is slow, but getting there, ive moved to devon so am without her for a while altho have a new workshop and moved the tools and bits today...car to follow shortl!
Bobtail,
I didn't want a single beadlock, if I'm going to do it I will do a double beadlock which will mean making in into a splitrim, not so pretty then.
Up until then I'll stick with the Stauns, but yep yours look well, who's done them?
Cheers
Bobtail,
Cheers
A lovely man called Grant, he is our local blacksmith and dedicacted offroader so he likes to make lots of goodies like beadlock rings, winch bumpers, cages, ground anchors, shock towers and all sorts for our club members,of which he is a committee member and he does a normal work as well.. As far as i know he will do bespoke work for anyone.
Jeff.
Bobtail,
Cheers
Twiggy, I've got a set of mac 5's with the rings fitted, i used to run them with simex before going to boggers.
Could be yours for a modest fee......... ;) cant use them on the new truck as they are 6 stud :rolleyes:
