ThreePointFive Posted December 16, 2008 Share Posted December 16, 2008 I've bought some carling switches for roof lights and other accessories, I'd like to mount the switches in the lower dash next to the steering column on the left, inbetween it and the cd player/clock/rear wipe controls. Looking at the securing clips on the rear of the switches, it looks like the dash is too thick for them to clip into. I was wondering where other people have mounted them (without using a mud pod) and if the dash thickness was an issue. Also where should I look to wire it in to the dash light circuit? I'm not overly happy to start chopping up wiring so might leave this to someone who knows what they're doing. Quote Link to comment Share on other sites More sharing options...
LiamC Posted December 16, 2008 Share Posted December 16, 2008 You can get mounts/surrounds for the switches which may allow them to be mounted to thicker materials? See http://www.mudstuff.co.uk/Carlingswitches.html Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted December 16, 2008 Author Share Posted December 16, 2008 I forgot to mention, they are already in a gang mount of 3 but even so the clips look too close to the rear of the switches to secure them to anything thicker than 2-3mm. Quote Link to comment Share on other sites More sharing options...
redben101 Posted December 16, 2008 Share Posted December 16, 2008 If i understand correctly you want to fit them where there is the oval panel which has screw to remove it? If so there is some 1.5mm ish metal behind there which will need trimming. Instead of chopping about the loop i bought a bluesea waterproof fuse box and took new feeds direct from battery. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted December 16, 2008 Author Share Posted December 16, 2008 I want to place them in the dash section between that oval and the steering column, approximately half an inch to the left if you draw an imaginary line from the centre of the vent flap handle. In behind that section there is a plastic panel that might be able to clip onto, so I'd like to see if anyone's tried something similar. Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted December 16, 2008 Share Posted December 16, 2008 I used to have a Mud Dash, which I sold to someone on here as I never got around to doing that particular job. I since bought a Croytec Pod for 3 gauges which sits where the ashtray is. I ended up only needing to mount 3 switches (rather than the 6 that the Mud Dash would have held) and these I mounted in a plate (also from Mudstuff) that sits where the ciggy lighter & rear wiper go. It is a metal plate that comes pre-drilled with the hole for your rear wiper & fag lighter & 3 switch mounts. I opened up the fag lighter hole a bit, and mounted a marine grade 12v socket in its place. It all looks really neat & tidy, especially since I added neat printed labels for each switch. As for the wiring, I believe electricity is Dark Arts, and left all that to my garage! Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2008 Share Posted December 16, 2008 I want to place them in the dash section between that oval and the steering column, approximately half an inch to the left if you draw an imaginary line from the centre of the vent flap handle. In behind that section there is a plastic panel that might be able to clip onto, so I'd like to see if anyone's tried something similar. similar place to these Britax SWF switches on my 110. hth Also where should I look to wire it in to the dash light circuit connect into the existing red/white wires behind the existing gauges or from the sidelight fuse power out side on the back of the fusebox. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted December 16, 2008 Author Share Posted December 16, 2008 Yeah that's almost exactly where I am planning on putting them. I think the carling ones with the surrounds are slightly larger. I suppose all I can do is cut the hole required and then see if they are securely held or not, I can always glue them once I'm sure which switches are going there, not sure if third should be for winch - which I don't have yet or work lamp which I do. Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2008 Share Posted December 16, 2008 those are in a 3 switch surround & all I did was cut the dash bit out & pushed the surround with switches installed into place, they sit there quite happily. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted December 17, 2008 Author Share Posted December 17, 2008 Thanks for the help, installed now and looking quite good. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted December 17, 2008 Share Posted December 17, 2008 Got any pictures? Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted December 17, 2008 Author Share Posted December 17, 2008 Here they are - looks pretty good in my opinion. They look at a slant because of the plastic trim above, they are near as I could get it in line with the dash line below. Quote Link to comment Share on other sites More sharing options...
western Posted December 17, 2008 Share Posted December 17, 2008 Tidy & smart job Sam Quote Link to comment Share on other sites More sharing options...
