bombx3 Posted December 28, 2008 Share Posted December 28, 2008 on my 90 on full lock i get a clicking from somewhere under the bonet but it doesnt do it on standard wheels,they arnt rubbing could it be the weight of the tyre over loading the steering box, Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 28, 2008 Share Posted December 28, 2008 Clicking on full lock is normally a knackered CV joint...but it would do it with standard rims too.... Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 28, 2008 Author Share Posted December 28, 2008 i hope not only done 700 miles Quote Link to comment Share on other sites More sharing options...
TomG Posted December 28, 2008 Share Posted December 28, 2008 Check the panhard rod bolts along with all the balljoint nut and the big nut holding the drop arm to the steering box - extra force of turning the larger tyres will be putting more counteracting force through the panhard. Mind you with 700 miles you'd think everything should be tightened from factory to the correct values. Also, are the tyres contacting the radius arm on full lock before the steering stop? maybe the steering stop needs to be wound out a bit? Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 28, 2008 Author Share Posted December 28, 2008 cheers for the replys i will go out and have a look after topgear Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 28, 2008 Author Share Posted December 28, 2008 couldnt spend to long down there but put it on the ramp and every bolt under there is loose all steering nuts, radias arms ect will spend more time tomorrow and may be speak to the supplying dealer as i havnt been off road yet Quote Link to comment Share on other sites More sharing options...
Ian M Posted December 28, 2008 Share Posted December 28, 2008 got any pics? sounds like a bit of a beast! Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 28, 2008 Author Share Posted December 28, 2008 not yet mate its the same spec as the one i am selling but new ,i didnt want a new one but the wife went to buy a new disco and we got another 90 instead after a test drive they are the dogs nuts Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted December 28, 2008 Share Posted December 28, 2008 What are you going to say to the dealer bearing in mind the problem only exists with the non standard bits fitted? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 28, 2008 Share Posted December 28, 2008 they are the dogs nuts regrettably loose nuts in this instance. did the dealer fit the wheels? Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 28, 2008 Author Share Posted December 28, 2008 i am going ask him about all the loose nuts though out, i have only done 2 miles with the set up now Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 28, 2008 Author Share Posted December 28, 2008 regrettably loose nuts in this instance.did the dealer fit the wheels? if fitted the springs shocks and wheels Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 29, 2008 Author Share Posted December 29, 2008 problem solved tightened all steering nuts ect which were not very tight Quote Link to comment Share on other sites More sharing options...
bluespanner Posted December 29, 2008 Share Posted December 29, 2008 Which nuts were loose exactly?? Nothing should be loose when it comes to steering. Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 29, 2008 Author Share Posted December 29, 2008 Which nuts were loose exactly?? Nothing should be loose when it comes to steering. Not sure but they were very nice about it the manager said they had no previous problems with these but speaking to the machanic he said he has done loads over the last six months ,earlier this year we brought a range rover sport and a mile down the road the supercharger seized up and after they repaired it the head gasket went ,i was so peed off i got a full refund Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 29, 2008 Author Share Posted December 29, 2008 What are you going to say to the dealer bearing in mind the problem only exists with the non standard bits fitted? i said fitted these beautifull wheels and tyres but my truck is falling apart and my old 1992 defender with the same is perfect WHY!!!!!!!!!!! answer was oh dear looks like they didnt tighten the nuts up from new we are sorry would you like coffee why we check your truck over Quote Link to comment Share on other sites More sharing options...
discomikey Posted December 29, 2008 Share Posted December 29, 2008 most likely to be the cv joint. mine did it. it will stop if you fill it up with thick transmission oil or grease do you know how to fill it up?? mikey Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 29, 2008 Author Share Posted December 29, 2008 most likely to be the cv joint.mine did it. it will stop if you fill it up with thick transmission oil or grease do you know how to fill it up?? mikey HELLO mikey,i do no how to fill them up but on a new truck i wasnt going to bother just let them do it thanks anyway Quote Link to comment Share on other sites More sharing options...
bombx3 Posted December 29, 2008 Author Share Posted December 29, 2008 its going like a dream now long live land rover merry amas Quote Link to comment Share on other sites More sharing options...
