reb78 Posted January 21, 2009 Share Posted January 21, 2009 Just picked up a nearly new GKN overdrive and was wondering if, apart from the instructions supplied, anyone had any tips/recomendations for fitting/maintenance?? (110 LT77s with defender LT230 transfer box) Quote Link to comment Share on other sites More sharing options...
SteveG Posted January 21, 2009 Share Posted January 21, 2009 Just picked up a nearly new GKN overdrive and was wondering if, apart from the instructions supplied, anyone had any tips/recomendations for fitting/maintenance?? (110 LT77s with defender LT230 transfer box) You might want to renew all gaskets, or replace with a good gasket sealant. Check sealing of solenoid and also remove a check speed sensor to make sure all is intact and the fit it again as per instructions once you have installed od. There's a tech archive article too on the gkn od. It's straightforward though. Steve Quote Link to comment Share on other sites More sharing options...
western Posted January 21, 2009 Share Posted January 21, 2009 if you need gaskets or seals contact Devon4x4.com, IIRC they took over the units from GKN & all the spares. have a look at this fitting thread here Quote Link to comment Share on other sites More sharing options...
101sean Posted January 21, 2009 Share Posted January 21, 2009 When fitting the countersunk bolts to the adaptor plate in the back of the box, clean both threads and use threadlock. Not mentioned in instructions and mine worked loose (possibly due to vibration in worn Tbox) The torque figure of 40Nm seems a bit low so I retightened mine a fair bit more. Otherwise the instructions cover it fairly well. Point others mave made is the oil change interval is a bit long. Yes D4x4 have the spares, just rebuilt mine as the working loose damaged a bearing. Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 22, 2009 Author Share Posted January 22, 2009 Just been on to Devon 4x4. They do indeed stock all of the spares and can source more from the States according to the lady i spoke to. I have ordered a Gasket and Seal kit. Just gotta wait for it all to arrive now! Quote Link to comment Share on other sites More sharing options...
lbj Posted January 22, 2009 Share Posted January 22, 2009 Just picked up a nearly new GKN overdrive and was wondering if, apart from the instructions supplied, anyone had any tips/recomendations for fitting/maintenance?? (110 LT77s with defender LT230 transfer box) Hi Just make sure to change the oil in the overdrive for every 10000 km (6000 miles), and use automatic gearbox oil. Do not pay antention to the manual as I believe it says oilchange for every 55000 km. We are very pleased with ours in the 110 TD5 STW which have don some 265000 km, and I believe the overdrive has done well over 175000 km now.......and yes I change the oil for every 10000km. best regards Lars Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 26, 2009 Author Share Posted January 26, 2009 Thanks for all the replies. Got the gaskets and the OD has arrived over the weekend. Just one more question.... The input gear assembly i will be removing is cross drilled as i've fitted a recon gearbox and wanted to avoid the worn gearbox mainshaft as suffered by the previous box which was used without a cross drilled input gear. The question really is - will the overdrive inhibit the lubrication of the mainshaft at all and cause mainshaft wear (as it is not cross drilled)? Is there anything to be done that can decrease the chances of this happening? Have you guys with overdrives experienced this wear as a result of fitting them? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted January 26, 2009 Share Posted January 26, 2009 It'll be fine the gear gets lubed by the overdrive units fluid & the mainshaft still gets lubed by the transfer box, no wear on mine since my OD has been fitted. pics of fiitting mine Here pic 1 at the bottom right. Quote Link to comment Share on other sites More sharing options...
