k9unit Posted February 21, 2009 Share Posted February 21, 2009 anyone know if u can buy a poly donut instead of the rubber type. Quote Link to comment Share on other sites More sharing options...
task Posted February 21, 2009 Share Posted February 21, 2009 I'm pretty sure you can change the prop for an earlier one and just take it out all together. I'm sure somone else will be along to clarify or deny this Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted February 21, 2009 Share Posted February 21, 2009 you can use a discovery 200 rear prop,but you have to change the diff flange to 200 type also. Quote Link to comment Share on other sites More sharing options...
streaky Posted February 22, 2009 Share Posted February 22, 2009 anyone know if u can buy a poly donut instead of the rubber type. I asked the same questions to one of the UK suppliers of the rubber doughnut...they said they would look into having them from Polyurathane. That was a few months ago and I haven't heard back anything...so at this point in time I think rubber is the only option. I asked a PU molding company here in Dubai if they can make them...they said the investment in making the mold is substancial and not cost effective for our small market...so I guess it's down to the big boys and distributors to get this done. Quote Link to comment Share on other sites More sharing options...
karlo Posted February 22, 2009 Share Posted February 22, 2009 you can use a discovery 200 rear prop,but you have to change the diff flange to 200 type also. You will need either the longer type 4 bolt flange STC4858 or a spacer ashcroft's number 539745, I'm told Paddocks also do the spacer. Quote Link to comment Share on other sites More sharing options...
teabag Posted February 22, 2009 Share Posted February 22, 2009 Or you can fit the later V8's prop and flange as they don't have the donut. Quote Link to comment Share on other sites More sharing options...
drkwack Posted February 22, 2009 Share Posted February 22, 2009 Hi, sorry to sound like an idiot but why do you want to replace it Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted February 22, 2009 Share Posted February 22, 2009 Is there a safety consideration with these donuts, I notice on mine when you drop the prop from the gearbox end there are splits/cracks in the rubber. Should I also be looking at replacing it with a new rubber / poly one ? Cheers Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 22, 2009 Share Posted February 22, 2009 my new to me disco had a cheap pattern donut last march and when the clutch was just done again the donut was allmost gone all the way through (some big splits in that) so new genuine donut fitted and we will see how long this one lasts rob Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 23, 2009 Share Posted February 23, 2009 the genuine ones are made by GKN, same as you can buy from Bearmach... Quote Link to comment Share on other sites More sharing options...
