gaz0203 Posted March 9, 2009 Share Posted March 9, 2009 hi i have a 1966 series 2 diesel and the axles are in a bad way, i also have an r reg series 3 diesel for spares, what id like 2 know is are these axles the same or have they many differences? Quote Link to comment Share on other sites More sharing options...
CJRH Posted March 9, 2009 Share Posted March 9, 2009 Axles are the same, so a straight swop over job. Chris Quote Link to comment Share on other sites More sharing options...
kingdong2 Posted March 9, 2009 Share Posted March 9, 2009 if both landys are swbs and the axles are std then yes they will fit but there is a chance that the s111 axles could be 24 splines but hopefully they will be 10 spline like your s11 axles ? graham __________________________ 1962 2a swb 200 tdi. Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted March 9, 2009 Author Share Posted March 9, 2009 will have to check, diffs should be the same ratio though should they aslong as there both dervs? Quote Link to comment Share on other sites More sharing options...
Rich_P Posted March 9, 2009 Share Posted March 9, 2009 Might have a different position for the drain hole or something too? But as said, they're otherwise the same. Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 10, 2009 Share Posted March 10, 2009 "quote if both landys are swbs and the axles are std then yes they will fit but there is a chance that the s111 axles could be 24 splines but hopefully they will be 10 spline like your s11 axles ? graham " Why? Surely 24 spline is an improvement on 10 spline? I thought that he will swap the complete axle so there would be no parts issues. Marc. Quote Link to comment Share on other sites More sharing options...
SUZUKINUTTER Posted March 10, 2009 Share Posted March 10, 2009 if both landys are swbs and the axles are std then yes they will fit but there is a chance that the s111 axles could be 24 splines but hopefully they will be 10 spline like your s11 axles ? graham they are still 10spline in the diff and 24 spline on hub end thats the difference but both axles will fit Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted March 11, 2009 Share Posted March 11, 2009 will have to check, diffs should be the same ratio though should they aslong as there both dervs? Are they different? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 11, 2009 Share Posted March 11, 2009 NO. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 11, 2009 Share Posted March 11, 2009 All rover-type Series diffs are 4.7:1 10-spline, youdo have to watch drain/fill plug holes as you can end up with no way of filling the axle but apart from that no difference. As has been said, Salisburys are different and later axles went to 24-spline hubs. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted March 11, 2009 Share Posted March 11, 2009 Can I ask what has happened to the old axle? Unusual to damage an axle casing - everything else is replaceable. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted March 11, 2009 Share Posted March 11, 2009 They can and do rot away, particularly the support braces on the rear axle (optional for front, as used by MOD). Quote Link to comment Share on other sites More sharing options...
ian_s Posted March 12, 2009 Share Posted March 12, 2009 the axle casing can also take damage if a diff goes bang in the wrong way my rear axle is leaking oil from 2 holes where my last died and bits jammed against the casing i'm not sure if i will just weld over the leaks or replace the casing yet Quote Link to comment Share on other sites More sharing options...
task Posted March 12, 2009 Share Posted March 12, 2009 the axle casing can also take damage if a diff goes bang in the wrong waymy rear axle is leaking oil from 2 holes where my last died and bits jammed against the casing i'm not sure if i will just weld over the leaks or replace the casing yet I thought the holes were in your diffpan Ian? Quote Link to comment Share on other sites More sharing options...
ian_s Posted March 12, 2009 Share Posted March 12, 2009 I thought the holes were in your diffpan Ian? yeah, but its all in one peice so i either weld it up or change the whole casing Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted March 18, 2009 Author Share Posted March 18, 2009 its the front thats the trouble, all brakes seized, swivel bearings colapsed and chrome gone of the swivels, just deemed it easier to use the s3 axle ive sgot thats in good nick, jst wanted 2 know if it woz a straight swap Quote Link to comment Share on other sites More sharing options...
