steve_a Posted June 17, 2009 Share Posted June 17, 2009 I think you're stuffed, you're running 64bit windows, microcat is 32bit (in fact bits are 16bit from Win 3.11!!!). I don't think you can even do any compatibility stuff. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 17, 2009 Share Posted June 17, 2009 in fact bits are 16bit from Win 3.11!!! This is the bit that kills it then, there's no more supoprt for 16-bit apps in Vista x64 IIRC, something to do with removing wowexec... Quote Link to comment Share on other sites More sharing options...
jacks906 Posted June 18, 2009 Share Posted June 18, 2009 when i was struggleing with cracking something i had to load it all up when i was off line dont know if this is the same tho Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 6, 2009 Share Posted August 6, 2009 Returning to this in the hope that there's a quick answer to the following... Reinstalling Mcat onto an XP system I'm repeatedly being presented with the error message 'uninstaller setup failed to initialize' after clicking 'ok' the setup instantly closes. Any ideas? TIA. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 7, 2009 Share Posted August 7, 2009 Any ideas? I take it that's a no then Quote Link to comment Share on other sites More sharing options...
tuko Posted August 7, 2009 Share Posted August 7, 2009 Steve, it seems to me that you have a bad copy. If you burned it yourself, then burn the cd again but at the lowest possible speed. Todd. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 7, 2009 Share Posted August 7, 2009 Interesting that you should say that Todd as I thought the same so tried to load it from a known good copy (ie one that I'd used before and found to be ok) but the problem still persists Quote Link to comment Share on other sites More sharing options...
tuko Posted August 7, 2009 Share Posted August 7, 2009 Steve, Is this a reinstall or a new install on a new computer? If a reinstall then you have remove all traces of the old install including the cracks. If on a new computer then try running windows update before try again. BTW the version your using Steve is it one or two cd's ? Todd. Quote Link to comment Share on other sites More sharing options...
sasha2001 Posted August 8, 2009 Share Posted August 8, 2009 Interesting that you should say that Todd as I thought the same so tried to load it from a known good copy (ie one that I'd used before and found to be ok) but the problem still persists I have sen this with my friends computer with Xp, it was the actual DVD drive could not read the discs correctly, had to change the dvd Reader/writer and it read both discs Quote Link to comment Share on other sites More sharing options...
steve_a Posted August 9, 2009 Share Posted August 9, 2009 Returning to this in the hope that there's a quick answer to the following...Reinstalling Mcat onto an XP system I'm repeatedly being presented with the error message 'uninstaller setup failed to initialize' after clicking 'ok' the setup instantly closes. Any ideas? TIA. To rule out the disc copy the contents of the disc to a directory and install from there, I'm pretty sure that will work - I haven't had a disk for ages and I remember installing at the start of the year. Try uninstalling via the control panel first and check that the folders have gone. hth Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 9, 2009 Share Posted August 9, 2009 Thanks chaps. The install is being done from a known good couple of discs (ie ones that worked before) so presumably it's an issue with the PC. Quote Link to comment Share on other sites More sharing options...
