v84x4 Posted March 26, 2009 Share Posted March 26, 2009 v8 to 200 tdi conversion so has anyone done this, are there any pitfalls i should be aware of ,also do you have any suggestion's thanks... Quote Link to comment Share on other sites More sharing options...
bigcos Posted March 27, 2009 Share Posted March 27, 2009 hi,, there easy to do m8 will need to chop engine mounts off chassis and the wiring is easy as well as long as you no wot your doing ... any probs let me no.. Quote Link to comment Share on other sites More sharing options...
v84x4 Posted March 27, 2009 Author Share Posted March 27, 2009 so i take it i need to move the engine mounts. Quote Link to comment Share on other sites More sharing options...
pw8757 Posted March 29, 2009 Share Posted March 29, 2009 I take it this is V8 Petrol to 200tdi? Really straightforward? Does it just plug into the same gearbox? Quote Link to comment Share on other sites More sharing options...
v84x4 Posted April 14, 2009 Author Share Posted April 14, 2009 well, so not many people done it then or did not many people see this post going to do it anyway see what happens Quote Link to comment Share on other sites More sharing options...
Rich_P Posted April 15, 2009 Share Posted April 15, 2009 I think the input shaft is different on the gearbox? Quote Link to comment Share on other sites More sharing options...
m&mv80 Posted April 15, 2009 Share Posted April 15, 2009 yep input shafts are different and i think the bell housing to, and yes the engine mounts will need to be moved you dont give much info, is it auto or manual? you will poss need to modify the fuel tank for a return and or remove the pump, depends what you got will need a diesel filter different rad and intercooler air box exhaust the wiring is pretty straight forward all depends how capable you are really Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted April 15, 2009 Share Posted April 15, 2009 Hi I did this conversion to a 1999 Defender V8 with R380 G/box. What year is yours as the pitfalls vary depending on gearbox fitted. I used 200TDI discovery engine, 300 tdi bell housing and V8 R380 gearbox and transfer box. A new bush was needed for the fly wheel housing and the input shaft splines are not quite long enough, its something I have to sort in the next few months as though it drives fine the clutch plate splines are not getting an easy life. On the defender the gbox mounts are diffrent for a v8 and transmit far more engine vibration than the 300 tdi type. I doubt I would do the conversion again unless I had the correct gearbox. Quote Link to comment Share on other sites More sharing options...
Batfood Posted January 29, 2014 Share Posted January 29, 2014 Hi - I've just came across this old thread via Google. I'm doing a NAS '96 Disco V8 to 300TDI conversion and I have just discovered that the input shaft is 12mm too short. How did you eventually solve the input shaft problem? thanks... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 29, 2014 Share Posted January 29, 2014 You should be using a diesel gearbox. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted January 29, 2014 Share Posted January 29, 2014 Is it not the bell housings that are different lengths? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 30, 2014 Share Posted January 30, 2014 The bellhousings are different (the engine pattern is different). The shaft is a different length and the pilot bearing is a different size. You need to fully pull apart the box to change input shafts. "Batfood" will have an auto. The torque converted and gear will all be wrong as well. Get a proper box for the engine. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted February 1, 2014 Share Posted February 1, 2014 The major problem when swapping in a Diesel engine in replacement of a v8 is that you become a homosexual in the process. Not sure if y'all ok with that? :/ Quote Link to comment Share on other sites More sharing options...
Batfood Posted February 4, 2014 Share Posted February 4, 2014 Thanks for the suggestions. @Red90 - It's a 1996 4.0L v8, 5-speed manual R380. Landrover Canada discontinued the manual box in 1997. The ratios are close enough, and to get a diesel gearbox out here is likely to involve (more) importation... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 6, 2014 Share Posted February 6, 2014 The ratios may be OK, but the input shaft is still wrong and needs to be changed, which requires a full box disassemble. As long as you are comfortable with gearbox internals, it is not a huge job.... I would contact Ashcroft and discuss options. You can decide if importing a rebuilt box and selling you existing box makes financial sense or if buying an input shaft and changing it over makes sense. A lot depends on your mechanical ability. Where in Canada are you located? Are you doing the work yourself or using a mechanic? Quote Link to comment Share on other sites More sharing options...
Boydie Posted February 9, 2014 Share Posted February 9, 2014 I just recently converted my 300TDi from an AShcrostZF$HP22/24 auto to R380 manual, from this "normal conversion" I can only advise you to expect a lot of minor problems, from slave cylinder push rod lengths to to prop shaft lenghts and nuts and bolts ---- it will be a lot of fun but dont expect it to be straight forward remember you're dealing with land rover and they aint easy or straight forward. Quote Link to comment Share on other sites More sharing options...
Batfood Posted February 23, 2014 Share Posted February 23, 2014 Thanks for the advice, gents. I'm based in Magog, Quebec. I'm doing the work myself, evenings and weekends. I've converted and rebuilt various vehicles in the past (Austin Mini van -> Cooper S drivetrain, several 60s Beeltes to bigger motors and earlier front-ends, etc.), and I have some LandRover maintenance experience, so I'm not a *total* newbie. As the wife is unlikely to tolerate a transmission on the kitchen table for 6 months, sounds like importing a rebuilt box will be the option that offers less chance of getting me divorced. I'm sure I'll be back with more questions. Cheers! Quote Link to comment Share on other sites More sharing options...
TBS123 Posted March 10, 2014 Share Posted March 10, 2014 Brilliant Quote Link to comment Share on other sites More sharing options...
