bodyworks on rather rusty RRC
denski
Hello from Russia!
I've purchased a rather rusty Range Rover Classic, and want to replace/weld all problem places. But I can't find a good story (with photos, part No's, etc) of restauration of such Rangies. Can you help me with links on such material?
Thanks.
Thanks for your reply, but I haven't got access to members vehicles forum yet. I have to make some quantity of posts here, before the administrator will allow my access there.
Anyway, thanks for your reply, mate!
I know that it's the common problem of rangies and discos.
I've read some your messages which are devoted to the rusty topic. Thanks for photos, they are very helpful.
The problems of my Rangie are quite common: a-pillars, rear wheelarches, outer and inner sill panels... Theese parts need to be replaced by the new ones. The main question is: try to order special replacement parts from UK or try to make them here in Russia. I'm searching for as many restoration reviews as I can, examine them and will make my decision.
Thank you very much for your support, because here in Russia very few people did the complete overhaul of rusty Range Rover body and your experience is very useful for me.
Rather than repairing the cills have a look for threads on DIY rock sliders.
Many have cut out the whole cill (inner and outer) and replaced it with a nice big steel box section which serves the purpose of curing the rust and also makes for a very strong underside.
Once this is in place it will make repairing the posts much easier.
Steve
Hi mate i followed the post by 'orange' but found it much easier to take out all the inner & outer sills replace them with 100x60x4mm box make new body mounts(simple) and easier than trying to weld to old sill then just weld the "a" "b" posts to the box section Would not have even attempted it tho if i had'nt have read that thread first truely inspirational
Hello from Russia!
Thanks.
Denski - If you're doing Cills or Pillars be sure to strip only one side at a time to avoid distortion of the body shell and make sure everything is well clamped up and braced before removing the old parts. Same goes for the rear crossmember - make sure the inner wings are supported before cutting out the old.
Will
Thanks for your answer, friend!
I decided not to buy replacement outer and inner sills, which seemed to me the best variant. It's impossible to find theese parts in Russia and buying them in UK and delievering to Russia seems much more difficult and expensive than replacing them by the box section you have mentined above.
Do you have any pics of your job?
Thanks once more.
