Grant. Posted March 27, 2009 Share Posted March 27, 2009 Hi all, Looking for gearbox fault codes for the nanocom(if such exists!) So before I get ridiculed, I am asking this on behalf of a friend who likes to pull my leg!! Have'nt seen it yet, all i know by his description is LG.... something something.... gearbox!! Sorry if it a bit vague, however looked on the tech archived and searched them however could'nt see anything on the nanocom fault lists!! Thanks Grant Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 27, 2009 Share Posted March 27, 2009 Sorry Grant, I think you friend is having a "Turkish". Nanocom only does engine and alarm ECU's and ABS & body control where fitted, check out - http://web.nanocom.it/nanocom_i.cfm?articolo=415 Besides - there's no electronics in a defender gearbox. Quote Link to comment Share on other sites More sharing options...
western Posted March 27, 2009 Share Posted March 27, 2009 as above, your friend is having a laugh, no electronics in a R380 gearbox. tell him Quote Link to comment Share on other sites More sharing options...
Grant. Posted March 28, 2009 Author Share Posted March 28, 2009 Hi Guys Thanks for the reponse!! I didnt think there was any electrickery in an r380!! However it does say gearbox, as it says below: we got a few letters wrong, but the description is still there!! Code(s) is/are : Fault 10-04 Gearbox/ABS drive open load - logged Fault 14-04 Gearbox/ABS drive open load - current Sorry I was a bit vague, just got to South Africa B) that evening and trying to sort his td5 for Safari!! Thanks in advance Grant Quote Link to comment Share on other sites More sharing options...
western Posted March 28, 2009 Share Posted March 28, 2009 could be the ABS module on the brakes that showing those codes not the main gearbox. http://forums.lr4x4.com/index.php?showtopic=33939 http://forum.landrovernet.com/showthread.php?p=1087129 those 2 threads might help Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 28, 2009 Share Posted March 28, 2009 I get the same faults logged on mine too, and quite a few others, but I don't have ABS (or Aircon.) The engine ECU appears to be geared up for all the possible options but if they're not fitted it detects that and throws up faults accordingly, would be nice if you could tell the ECU that these options are not fitted and to not generate the codes but I can't find any options to do it, not with Nanocom anyways. Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 28, 2009 Share Posted March 28, 2009 As above, if they are not fitted just ignore them. You can't turn them off on any of the Diag kit, T4 included. Steve Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 28, 2009 Share Posted March 28, 2009 I get the same faults logged on mine too, and quite a few others, but I don't have ABS (or Aircon.)The engine ECU appears to be geared up for all the possible options but if they're not fitted it detects that and throws up faults accordingly, would be nice if you could tell the ECU that these options are not fitted and to not generate the codes but I can't find any options to do it, not with Nanocom anyways. The more sophisticated diagnostic systems like IDS mask the carp fault codes if they aren't relevant to the vehicle spec - for example on an early T4 diagnostic version and an early Td5 Defender you always get a fault code for open circuit on the tachometer (rev counter) drive - because no factory Td5 Defender has one but the ECU looks for it because it might be a Discovery .... later versions cover this up because it is obviously a gash code which doesn't apply I honestly doubt whether Nanocom offers this but for the price you have to expect corners to be cut Quote Link to comment Share on other sites More sharing options...
