BigMac1 Posted April 23, 2009 Share Posted April 23, 2009 On the disco engine I've put in my 90 there's a switch/sensor on the thermostat housing. Is it a switch/sensor for the fans? Just wondering if I could use it to wire in an electric fan? Its the same as the twin pinned switch/sensor in this picture that I've stolen from the web...... Cheers Mick. Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2009 Share Posted April 23, 2009 that's the location for the air condition system temp switches, the actuall housing contains the cooling system thermostat. Quote Link to comment Share on other sites More sharing options...
ian_s Posted April 24, 2009 Share Posted April 24, 2009 i was thinking of getting the top thermostat housing on my 200tdi drilled and tapped to take a switch, i didnt think that landrover might have already done it! does anyone have an idea of how much one of those housings costs new? or am i better off looking for a second hand one? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 24, 2009 Share Posted April 24, 2009 i would imagine its going to be cheaper to simply drill and tap your existing one? it looks like alloy... Quote Link to comment Share on other sites More sharing options...
markyboy Posted April 24, 2009 Share Posted April 24, 2009 On the disco engine I've put in my 90 there's a switch/sensor on the thermostat housing. Is it a switch/sensor for the fans? Just wondering if I could use it to wire in an electric fan?Its the same as the twin pinned switch/sensor in this picture that I've stolen from the web...... Cheers Mick. Don't think it's adviseable to use a fan switch in this position. You'd find that the fan would be running most of the time because this will be one of the hottest points in the cooling system when the thermostat is open. A fan switch normally goes about 1/3 of the way up from the bottom of the radiator. On retro fits, most people put them in the bottom hose with an adaptor like the one from X Engineering. Regards, Mark. Quote Link to comment Share on other sites More sharing options...
AD90 Posted April 24, 2009 Share Posted April 24, 2009 I did that exact modification (drilled and tapped the 'stat housing) I fitted a 93degC switch and have only seen the fans on once. It's a lot better than the cr@p idea peddled by that well known fan manufacturer and a lot cheaper and neater IMHO than the X-fan thingy. I keep meaning to put up some pics of my electric fan set-up,,,,,one day. AD90 Quote Link to comment Share on other sites More sharing options...
BigMac1 Posted April 25, 2009 Author Share Posted April 25, 2009 Cheers for the replies guys. AD90, some pics would be nice. Sure others would appreciate it aswell. Although an X-Fan controller may be on my birthday list. Mick. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 25, 2009 Share Posted April 25, 2009 If you are hinking of asking a dealership the price, do two things. Be sitting down and have the whisky handy. I run my fan switch from that position. Never had a problem with ambient temperatures up to and above 45Deg C mike Quote Link to comment Share on other sites More sharing options...
