nas90 Posted April 30, 2009 Share Posted April 30, 2009 I am ordering 3mm thick Domex 700 Friday 1st May in the morning The cost of freighting is quite high and to order 1 or 2 sheets is quite frankly a waste of time. Therefore if any of you want some of this high strength material, now is the time to let me know so that I can place an order for all the types and thicknesses. I will happliy slice sheets into regular rectangles on the lasers for free but the cost of freighting will be charged along with the pro-rata cost of material. Sheet sizes from SSAB do vary can be 3000x1250mm or 2000x1250mm or somewhere in between! So I would supply a minimum of 1250mm wide by 500mm increments along the sheet. I only really want to offer to LR4x4 members so don't go and post this on all other forums! The SSAB website is here http://www.ssab.com/ Nick at the forge has now made his challenge truck and used 3mm Domex and would have used 1.5mm Docal 1000 if I could have supplied that grade. I can do a laser cutting service but pm me off the forum because there is a conflict of issues for me to use the forum for advertising. Guy apparantly had issues with drills being blunted at the forge whilst making Nick's truck, so remember this stuff is TOUGH and needs appropriate tools. Any questions pm me. Remember you have slightly less than 24 hours before I need to place a material order...................... I cannot offer freight outside of UK mainland, sorry for you Aussies! Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 30, 2009 Share Posted April 30, 2009 Nas is this a simular product to Hardox ? Quote Link to comment Share on other sites More sharing options...
nas90 Posted April 30, 2009 Author Share Posted April 30, 2009 Nas is this a simular product to Hardox ? Yes and no! Hardox is a wear resistant material, Domex and Docal are used more for fabrication. For example, Domex 700 for the chassis of an earth mover to reduce weight over a mild steel chassis, Docal for reduction in weight of cover panels and Hardox for good wear resistance in the bucket of the earth mover. Hardox was in short supply last year and SSAB were only supplying their big customers. If you need Hardox then I would need to check tomorrow morning. Check out the SSAB website above, all the material types are explained Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 30, 2009 Share Posted April 30, 2009 Its ok I have a bit left over from a tipper bed rebuild , Thought it would make a nice winch bumper , But its so hard its a right bugger to bend . Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 30, 2009 Share Posted April 30, 2009 Domex is similar - a real bu&&er to bend. Makes it perfect for cage spreader plates, winch mounts etc. B) Quote Link to comment Share on other sites More sharing options...
simonr Posted April 30, 2009 Share Posted April 30, 2009 Domex is similar - a real bu&&er to bend. Makes it perfect for cage spreader plates, winch mounts etc. B) Not to mention X-Anchors! Good material! Si Quote Link to comment Share on other sites More sharing options...
nas90 Posted May 1, 2009 Author Share Posted May 1, 2009 Time-up chaps, I must go and order material for more X-Eng anchors, so 3mm Domex700 only will be in stock. Dave Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 1, 2009 Share Posted May 1, 2009 Nigel wants 3 tons for his new winchbumper Quote Link to comment Share on other sites More sharing options...
nas90 Posted May 1, 2009 Author Share Posted May 1, 2009 Nigel wants 3 tons for his new winchbumper Is that measured from the dumb irons with or without the rubber bungs.................. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 1, 2009 Share Posted May 1, 2009 Right your banned Anyway, Better than Vapourex - that seems to be in massive over supply Nige Quote Link to comment Share on other sites More sharing options...
