tube thickness
dave g
im just about to order some steel tube for the rear tray and front wing and carnt deside on what thickness of tube to get its so would like alittle help
the choises i have is 50.8 x 2.03 or 50.8 x 3.2 as i say it not suporting the cage or anything but will be mounted to th same spreader plates as the rear stays of the roll cage thank dave
50.8 ? .........thats CDS then ?
Either of the wall thicknesses you mention are strong, stronger than Blue Band, but the usage is a tad
different, ie sqeezing against a tree etc can flatten / bow a tube easier than you'd thing, if the weight
isn't an issue then go for the thicker as that the only downside :)
Nige
Nige
Reducing the diameter will improve impact resistance but will bend easier, so maybe smaller and thicker is the best way forwards?
Like 45mm x 2.5mm :) - this still complies with the MSA requirements too. Not that it's a concern for you here, though....
