ROGUE TROOPER Posted March 9, 2006 Share Posted March 9, 2006 Is this possible, has anyone done it? I feel an auto would be better now that im old!! Ta Quote Link to comment Share on other sites More sharing options...
Mark90 Posted March 9, 2006 Share Posted March 9, 2006 Yes it's possible, yes it's been done, and no you can't get the kits any more. Can't remember who it was who used to do the kit, Ashcroft or Milner or....... Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 9, 2006 Share Posted March 9, 2006 Beleive it was ashcrofts. I had one of the ashcrofts LT77 conversion kits, and frankly it was horrible. I made my own in the end. However having done it I'd say its not woth the agro. Fit the autobox and transfer box and convert it to part time 4wd (assuming it uses the LT230 of course!) Jon Quote Link to comment Share on other sites More sharing options...
Mark90 Posted March 9, 2006 Share Posted March 9, 2006 LT230 doesn't fit the BW65/66, it's a Jag box. One of the advantages of using BW65/66 and series transfer box is the size, much shorter than a ZF or TF727 and LT230, which mean it will fit in a SWB series without having the V8 sticking out the front. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted March 9, 2006 Share Posted March 9, 2006 The original conversion was by ashcrofts, i've had two of their conversions off them to date both were supurb. Only real problem i came up against was the jag boxes not taking 250hp too well (kept losing reverse). Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 9, 2006 Share Posted March 9, 2006 Hmmmmmmmm a mate of mine has a Jag autobox in his 3.9V8 bowler so I'm guessing its one of these. He's forever blowing it up! Was rebuilding it 2 or 3 times a year at one stage......now talking about fitting a torqueflite....... Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 9, 2006 Author Share Posted March 9, 2006 Cool, thanks all, next is hunt the kit!! Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted March 9, 2006 Share Posted March 9, 2006 Hmmmmmmmm a mate of mine has a Jag autobox in his 3.9V8 bowler so I'm guessing its one of these. He's forever blowing it up! Was rebuilding it 2 or 3 times a year at one stage......now talking about fitting a torqueflite....... I,ve been the chrysler727 (torqueflight) route killed that as well. zf 4 speed is the only one to take the pain so far. Quote Link to comment Share on other sites More sharing options...
will_warne Posted March 9, 2006 Share Posted March 9, 2006 I,ve been the chrysler727 (torqueflight) route killed that as well. zf 4 speed is the only one to tack the pain so far. Was it a propperly built 727? In LR form they're not that strong but when built propperly not much is stronger. They need to be kept cool, though, IIRC. Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted March 9, 2006 Share Posted March 9, 2006 Was it a propperly built 727? In LR form they're not that strong but when built propperly not much is stronger. They need to be kept cool, though, IIRC. Agreed. They can be built to take close to 1000hp and did run behind big blocks in standard form, albeit uprated from the RR version. Cooling is next to Godliness Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted March 9, 2006 Share Posted March 9, 2006 Was it a propperly built 727? In LR form they're not that strong but when built propperly not much is stronger. They need to be kept cool, though, IIRC. It was a boggo low mileage rr one. and it was on a big cooler Quote Link to comment Share on other sites More sharing options...
minivin Posted March 9, 2006 Share Posted March 9, 2006 I feel an auto would be better now that im old!!Ta oh bless Quote Link to comment Share on other sites More sharing options...
Mark90 Posted March 9, 2006 Share Posted March 9, 2006 Agreed. They can be built to take close to 1000hp and did run behind big blocks in standard form, albeit uprated from the RR version. Cooling is next to Godliness It was more a case of the RR one was down rated. Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 10, 2006 Author Share Posted March 10, 2006 Bear in mind that behind my 3.5EFi is a std series 2a box!! Its not a trialer or an megga off roader so I think the BW65/55 convertion will be good. Quote Link to comment Share on other sites More sharing options...
Millsy Posted March 11, 2006 Share Posted March 11, 2006 JW over on ORRP has done this conversion Rogue on a Lightweight (Streakys??) Nice idea and I'd be tempted for mine if I could find all the bits. Quote Link to comment Share on other sites More sharing options...
