Dashboard
Mr Bean
puma dashboard would be a vast amount of work for very little gain. However, any defender dash would fit easily, all the holes are in the same places, td5 would fit but there is a bracket in the centre of a td5 bulkhead that the series doesnt have, you could fabricate that mount although you'd probably find it strong enough without it. So any dash would fit from the defender, td5 needs work but would still fit.
Hope that helps
Dave
the only problem i can see is the speedo, the series uses a squashed cable end drive so its an oval, whereas the defenders cable is shaped into a square and so the defender speedo cant be driven by the series transmission unless someone's found a way around it?
The series speedo does fit the defender dash though
Dave
well i dont know what i'd do, from the sound of the last post, the series cable would be a tight enough fit in the defender speedo that it should work, i'll probably try to fit the cable and if it doesn't like it then just swap the speedo units over.
Dave
