keithjh Posted June 9, 2009 Share Posted June 9, 2009 Reccomended pressures please from you that know these things for 265/75/16 tyres on steel rims. Thanks Keith Quote Link to comment Share on other sites More sharing options...
nicks90 Posted June 9, 2009 Share Posted June 9, 2009 depends on the brand of tyre, how much weight you carry etc. although there are manufacturers recomended pressures, i found them to be way off when i fitted greenway machos to my 90. After lots of upping and downing of pressures, i have finally settled on 32psi front and 30psi rear for normal road driving. When loaded or towing, the rears go up to 36psi. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 9, 2009 Share Posted June 9, 2009 http://forums.lr4x4.com/index.php?s=&s...st&p=180410 Nige Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 9, 2009 Share Posted June 9, 2009 The handbook has recommended pressures for them fitted on alloys - I don't have the book handy at the moment. I run mine at about 25/30 front rear on the 110, but thats with no high speed use Quote Link to comment Share on other sites More sharing options...
Athena Posted June 9, 2009 Share Posted June 9, 2009 Reccomended pressures please from you that know these things for 265/75/16 tyres on steel rims.Thanks Keith Hi Keith I put 235/70/16 on my 90 recently as i do a lot more motoway miles, but i run at 32psi on fornt and 34 on the back Dan Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 9, 2009 Share Posted June 9, 2009 Book says:- 28/35 for 265s on a 90 28/40 for 7.50s on a 90 28/48 for 7.50s on a 110 So whether you use the 90's pressure, or up the 90's rear pressure by 8psi (that being the difference in the pressures for 7.50s between a 90 & 110) is up to you. There isn't a published pressure for 265s on a 110 because they never fitted them. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 9, 2009 Share Posted June 9, 2009 I run 28 front and 30 rear with bfg at's. Spot on at that for me. Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted June 11, 2009 Share Posted June 11, 2009 My 90 handbook states pressures for the 265/75 tyres as 28 Front 36 Rear. For me the rear is way too high as I don't carry any weight. Currently they sit at 30PSI all round, with quite a bit of bulge and if hitting a rough patch on the motorway at 60 they don't feel as secure (if that's the right word) as when I run them at higher pressures. However for me at the moment it is mostly town driving, and if I do use the motorway it's 50-55mph so this pressure suits me fine for comfort and even wear. I will shortly be doing the 'chalk' tyre test to make sure they are wearing evenly Quote Link to comment Share on other sites More sharing options...
