Jammy123 Posted June 24, 2009 Share Posted June 24, 2009 Im after a roof rack to hold my spare tyre and some tracmats. Its for a 90. I want something 'cheap' no more that £200 and would like a rear ladder too. I have seen the roof racks from Craddocks for £170ish, and First Four do 3 roof bars for £170ish too. Any experiance with these? Cheers. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 24, 2009 Share Posted June 24, 2009 Get a fully welded galvanised type not a pack flat bolt together one - they tend to fall to bits with a spare wheel on. Roof bars are probably under specified for permanently carrying a spare wheel as well, unless they are a lot stronger than my Thule ones. I'd sooner get a second hand Brownchurch within your budget than a new cheapy. Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 24, 2009 Share Posted June 24, 2009 I'd sooner get a second hand Brownchurch Seconded. B) I've had mine for years, in fact the previous owner put it on. He used it for a roof tent for a trip to Morocco. Now the spare lives on it, it gets walked on, has had 11 kayaks on it, stuff gets dropped on it, including big tree branches a few times. No dents, no rust, looks like new. Well worth the money. Quote Link to comment Share on other sites More sharing options...
A Twig Posted June 25, 2009 Share Posted June 25, 2009 Second hand Patriot, nuff said, although you might have to stretch to a bit over £200. I love mine... Quote Link to comment Share on other sites More sharing options...
dave88sw Posted June 25, 2009 Share Posted June 25, 2009 if you have a big wheel it raises the centre of gravity to have it on the roof and the max weight stated is 75kg, a rack and wheel will go over this. Ok, so nobody pays any attention to that figure but i thought maybe worth a mention. I too would say get a brownchurch or fully welded galvy one, i got a genuine galvy one for £50 second hand so they are out there. Dave Quote Link to comment Share on other sites More sharing options...
specialbikejames Posted June 25, 2009 Share Posted June 25, 2009 The First Four bars are nicely made, I picked up my bumper/winch direct from their premises and they had the bars on their 110. They fit much better than a cheap roofrack as they sit very close to the roof line. Brownchurch racks are tough but they aren't exactly close fitting! Most ali racks are stupidly priced and they go for big money on ebay too. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 26, 2009 Share Posted June 26, 2009 I have a galv brownchurch one and its excellent, although chuffing heavy! Don't ever buy anything that has that stupid plastic rislan (sp?) coating, they rust though quickly then you cant paint them without taking all the plastic off! Mike Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 26, 2009 Share Posted June 26, 2009 Another vote for Brownchurch - mine is mearly 20 years old and good as new. Carries the spare wheel and garden sheds, wardrobes and any other big junk i chuck up there to carry around (i am aware of the 70 kg weight limit!). Quote Link to comment Share on other sites More sharing options...
alantd Posted June 29, 2009 Share Posted June 29, 2009 The weight limit obviously includes the weight of the rack as well. The galvanised ones are damned heavy so your official load capacity is significantly reduced. Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted June 29, 2009 Share Posted June 29, 2009 I just gave a Brownchurch away for nothing! Brownchurch are brilliant bits of kit, but I needed the best roof rack available (was that a can of worms?) so got myself a Patriot to replace it with. They cost a hell of a lot more than a Brownchurch, but are well worth it. Even secondhand, you would still be looking at several hundred pictures of the Queen for one! If you only need it for a spare wheel and trac mats, and occasionally the odd bit of stuff that needs shifting, then a Patriot would probably be overkill. I would certainly get a Brownchurch if i was in the same position. Keep a look out, they come up fairly often and usually under your £200 budget HTH Martin Quote Link to comment Share on other sites More sharing options...
