ibexman Posted June 25, 2009 Share Posted June 25, 2009 anyone got pics of arb switches mounted on cubby box or any were else where are yours ????? cheers chris Quote Link to comment Share on other sites More sharing options...
Orange Posted June 25, 2009 Share Posted June 25, 2009 No pics, I'm afraid, but I can take some later tonight if you like. Mine are mounted on a MSS cubby box at the bottom of the stereo section at the front on the drivers side. The stereo section only has a CB in it so there is plenty of room for all the wiring at the rear of the switches. I also have 3 winch switches and front & rear spot/worklight switches mounted in this space. My old 90 had an aluminium panel with 3 switches in it mounted up the side of the stereo section, with the stereo bit mounted off to one side (rather than central...) If you are mounting them in a 'standard' cubby box, I would highly recommend putting a cover panel over the wiring inside the box... Quote Link to comment Share on other sites More sharing options...
streaky Posted June 25, 2009 Share Posted June 25, 2009 Mine are in a Discovery but the wiring loom doesn't take up much space so you should be able to put them almost anywhere. I was able to use the slide out ashtray compartmen to mount mine. Quote Link to comment Share on other sites More sharing options...
white90 Posted June 25, 2009 Share Posted June 25, 2009 Quote Link to comment Share on other sites More sharing options...
clbarclay Posted June 26, 2009 Share Posted June 26, 2009 Is this for a specific model of land rover or ARB switch locations in general? Quote Link to comment Share on other sites More sharing options...
stravaigin Posted June 26, 2009 Share Posted June 26, 2009 Tony, what is that to the right of your sterio (No. 29)? Is it OAT? more info please? My ARB switches are in the same place, works well for me. Kev Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 26, 2009 Share Posted June 26, 2009 EGT gauge - measures exhaust gas temperature via a probe in the manifold Tony has the same one as me see here http://forums.lr4x4.com/index.php?showtopic=1298 Quote Link to comment Share on other sites More sharing options...
stravaigin Posted June 27, 2009 Share Posted June 27, 2009 EGT gauge - measures exhaust gas temperature via a probe in the manifoldTony has the same one as me see here http://forums.lr4x4.com/index.php?showtopic=1298 Thanks BM Quote Link to comment Share on other sites More sharing options...
webbsite Posted June 27, 2009 Share Posted June 27, 2009 Well, This is how I did mine on my Traka, its the same as any Classis RR. I did however include internal winch controls for the dual Milemarkers. regards, Roger Quote Link to comment Share on other sites More sharing options...
TSD Posted June 27, 2009 Share Posted June 27, 2009 I don't have any pics of this panel installed, but this is the CNC panel I had made for the Ibex. Quote Link to comment Share on other sites More sharing options...
