Stroppy Cow Posted September 17, 2009 Share Posted September 17, 2009 Am thinking of putting a k and n air filter onto my 2.1/4 petrol.....will this be a good or bad thing????and will it need re tuneing????? Quote Link to comment Share on other sites More sharing options...
nick w Posted September 17, 2009 Share Posted September 17, 2009 why Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 17, 2009 Share Posted September 17, 2009 It won't filter anything out and it's not going to improve the standing 1/4 mile times of the 2.25 lump. Stick with the oil bath or stick a later paper element air box on, at least they stop things going in, and a 200TDi filter is by definition designed to flow at least twice as much air as your engine can suck in. Quote Link to comment Share on other sites More sharing options...
Stroppy Cow Posted September 17, 2009 Author Share Posted September 17, 2009 It won't filter anything out and it's not going to improve the standing 1/4 mile times of the 2.25 lump. Stick with the oil bath or stick a later paper element air box on, at least they stop things going in, and a 200TDi filter is by definition designed to flow at least twice as much air as your engine can suck in. thats answered that then....i wont be putting one on.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 17, 2009 Share Posted September 17, 2009 I run a Defender 200TDi airbox & filter on my 4.6 and it seems to work well enough - and a new paper element is £10. Quote Link to comment Share on other sites More sharing options...
Stroppy Cow Posted September 18, 2009 Author Share Posted September 18, 2009 I run a Defender 200TDi airbox & filter on my 4.6 and it seems to work well enough - and a new paper element is £10. think i just asumed that if i put a easier flowing air filter on the engine would work a little better..just looking for ways to make the engine a little happier....im well aware it,ll never be quick just fancied treating the old girl... Quote Link to comment Share on other sites More sharing options...
Quagmire Posted September 18, 2009 Share Posted September 18, 2009 My brother has one on his 2.25 lightweight at the mo whilst he sorts out fitting an SU and proper filtration. It makes a hell of a noise compared to my 2.25 with oil bath filter. Too much. Sounds like when you finish a milkshake with a straw, which is a shame because his engine actually sounds really nice... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 18, 2009 Share Posted September 18, 2009 The whole K&N thing has been done over before: http://forums.lr4x4.com/index.php?showtopic=9339 (and it's worth noting that HiClone thingies mentioned in this thread are complete snake oil too) http://forums.lr4x4.com/index.php?showtopic=31190 http://forums.lr4x4.com/index.php?showtopic=40550 Quote Link to comment Share on other sites More sharing options...
andyb Posted September 18, 2009 Share Posted September 18, 2009 (and it's worth noting that HiClone thingies mentioned in this thread are complete snake oil too) Is that a snake oil bath filter?! OK sorry, nothing else to add Quote Link to comment Share on other sites More sharing options...
Gazzar Posted September 18, 2009 Share Posted September 18, 2009 Best filter for naturally aspirated engine is an oil bath. If you want to increase the air flow because you have increased the flow downstream then fit an oil bath from a 2.6 prtrol. If you haven't flowed the head, increased the fueling and a wider bore exhaust then don't bother. Check your tyre pressures and ensure your bearings are set right and you'll gain more performance and MPG. G. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted September 18, 2009 Share Posted September 18, 2009 If you want to find out how much the current air cleaner reduces power - simply disconnect it and go for a drive (obviously not across a dusty desert). Quote Link to comment Share on other sites More sharing options...
