spring pins
danielh110
A bit specialised, I'd look under "Springs & Shock Absorbers" in Yellow Pages.
I assume you mean the pins that go through the centre of the spring, not those that go through the eyes, they are standard Landrover parts.
Wouldn't any decent bolt do?
G.
From memory an M8 or M10 cap head bolt works pretty well. It's not exactly a fine tolerance application, and the U-bolts should be holding the spring on.
Doh! Cap heads - why did I not think of them? Used to use them all the time in my old job. Perfect solution!
ok im trying to get hold of some pins for the leaf springs on a series 3. the springs have been stripped and overhauled but they cant go back together untill i have some new pins <_<
any ideas??
cheers
dan
give us a shout on here or LOC if you need machining mate ;)
