Dan88 Posted December 8, 2009 Share Posted December 8, 2009 Last night i was driving my defnder to my gf's and the indicators were working fine, a little further and they started to play up... 1st they trailer signal on the dash illuminated when indicting.... (not normal) 2nd the indicators stopped flashing and just stayed on 3rd they started working but flashing very slowly 4th the stopped all together... on the way home this morning the worked slowly again for a little while and the stopped... i checked the fuse and all ok and ideas??? Quote Link to comment Share on other sites More sharing options...
errol209 Posted December 8, 2009 Share Posted December 8, 2009 Last night i was driving my defnder to my gf's and the indicators were working fine, a little further and they started to play up... 1st they trailer signal on the dash illuminated when indicting.... (not normal) 2nd the indicators stopped flashing and just stayed on 3rd they started working but flashing very slowly 4th the stopped all together... on the way home this morning the worked slowly again for a little while and the stopped... i checked the fuse and all ok and ideas??? - Water in the wiring (take all the bulbs out and see what happens) - New flasher unit required - Hazard switch going defunct (sit down before looking at prices or fit a Carling one) Quote Link to comment Share on other sites More sharing options...
suggs Posted December 8, 2009 Share Posted December 8, 2009 - Water in the wiring (take all the bulbs out and see what happens) - New flasher unit required - Hazard switch going defunct (sit down before looking at prices or fit a Carling one) sounds like the flasher unit Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 8, 2009 Share Posted December 8, 2009 Mine did a similar thing on Sunday on the way to Brick Kiln in the peeing rain. Water found it's way into the fusebox and the flasher relay got wet. Once it was dried out it was fine. Check your flasher relay, open it up if you can and check the PCB for wetness and corrosion etc. Quote Link to comment Share on other sites More sharing options...
western Posted December 8, 2009 Share Posted December 8, 2009 trailer indicator icon should light once then go out when left or right indicator selected with NO trailer attached, with a trailer attached the icon should flash with the vehicle indicator light & it'll flash when Hazard lights are in use with or without a trailer attached. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted December 8, 2009 Share Posted December 8, 2009 I have a spare Hazard switch if that turns out to be the problem... Quote Link to comment Share on other sites More sharing options...
Dan88 Posted December 8, 2009 Author Share Posted December 8, 2009 got home tonight ready to have a look and all seems to be working again as it should.. hopefully it was just a blip and sorted out now, very hopeful i know... if it goes tho now i know what to do, thanks to everyone for their help. Quote Link to comment Share on other sites More sharing options...
patch1 Posted December 8, 2009 Share Posted December 8, 2009 My dad had his indicators go funny and it turned out to be the rear loom had chafed through were it gose into the chassis at the front under the drivers foot well. Quote Link to comment Share on other sites More sharing options...
