MogLite Posted April 24, 2006 Share Posted April 24, 2006 I've been striping down the wiring loom from a 1991 EFI Rangie ready to transplant only the necessary bits into MogLite. I've got a few bits that are troubling me, and its a right pain in the eyes trying to pick them out of the wiring diagrams. First one 2nd one - seems to be a changeover relay 3rd one - I haven't got a scoobie Last one - a Hella relay Hopefully some of you will seen these before and will instantly know what they are. Many thanks, from me and my optician Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2006 Share Posted April 24, 2006 1 ??? 2 could be a rear fog light relay, just going on the red/yellow cable colours 3 is a dimdip transformer, this allows the dip beam part of the bulb to come on with sidelights at about 10% brightness, fitted to vehicles to prevent them being used in built up areas on sidelights only, just to make the vehicle more visible to dumb/stupid pedestrians. 4 could be a lighting or headlight relay Quote Link to comment Share on other sites More sharing options...
MogLite Posted April 24, 2006 Author Share Posted April 24, 2006 Nice one Western - thats one in the bin On the first one is written 2455 RBV 260 908 L10C Made in the UK 46-90 There is a tag on the black wire with 4890 on it Apart from the black wire, the red/slate changes to a blue/black after the connector !! Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2006 Share Posted April 24, 2006 Does that transformer work? cos mines packed up, I'll give it a new home if your not going to use it. Quote Link to comment Share on other sites More sharing options...
MogLite Posted April 24, 2006 Author Share Posted April 24, 2006 Does that transformer work? cos mines packed up, I'll give it a new home if your not going to use it. Dunno TBH - PM me an address and I'll bung it in a Jiffy bag, and you can find out for yourself Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2006 Share Posted April 24, 2006 Dunno TBH - PM me an address and I'll bung it in a Jiffy bag, and you can find out for yourself OK, PM on way Cheers PM sent Quote Link to comment Share on other sites More sharing options...
MogLite Posted April 24, 2006 Author Share Posted April 24, 2006 Seems the Hella one is a headlight washer. Found this Audi link with all kinds of relay codes. I found it by putting the pin numbers into Google !! Western - PM recieved. Leave it with me. Quote Link to comment Share on other sites More sharing options...
V8RRC Posted April 24, 2006 Share Posted April 24, 2006 Hi Guys, I recall seeing item 1 on my RR & after looking what it was when I found mine it is the thermostat for the heated washer jets & is normally located behind the grille by the drivers headlamp! Hope this helps! Regards, Quote Link to comment Share on other sites More sharing options...
MogLite Posted April 24, 2006 Author Share Posted April 24, 2006 Hi Guys,I recall seeing item 1 on my RR & after looking what it was when I found mine it is the thermostat for the heated washer jets & is normally located behind the grille by the drivers headlamp! Hope this helps! Regards, Nice one - the colour codes check out - another one for the back of the bin Quote Link to comment Share on other sites More sharing options...
MogLite Posted April 24, 2006 Author Share Posted April 24, 2006 and the green relay is used for driving the low water level warning light Well at least I think it is. The pin-outs certainly match with this How-to but I can't find it on my wiring diagram. Not to worry - it was one of the relays I was looking for !! Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2006 Share Posted April 24, 2006 Western - PM recieved. Leave it with me. OK, will let you know if it works or not. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 24, 2006 Share Posted April 24, 2006 Wrong wrong wrong: In order they are: A doodaah A thingummy An oojumiflip A whossname And a doohickey If you need any flux capacitors I found a box of them the other day - no, really! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 24, 2006 Share Posted April 24, 2006 Andy, wiring. um yeah well er Absolutely no idea BUT, you are welcome to borrow my genuine LR Parts manual, flick through and see if you can find them )ie) in one of the parts pics, or I could send you a Microcat CD Nige Quote Link to comment Share on other sites More sharing options...
