markpc Posted January 29, 2010 Share Posted January 29, 2010 Hi, I've just bought a 1992 110 which is in excellent condition. It replaced my old 90 which had an extremely rusty bulkhead, which I couldn't justify spending money to replace. I want to ensure my new one doesn't go the same way, so I'm wanting to waxoyl the inside of the bulkhead. Does anyone have any advice how to do this without removal (& tipping it upside down)? I think I can get my cavity wax sprayer into the top corners (& door pillars) by drilling a hole in the bulkhead just underneath where the bonnet closes, does this sound right? My last landie's bulkhead rusted between the 'air vent flaps' and the bottom of the windscreen frame seal. What could I do to get wax into the top middle bits of the bulkhead? Could I access this bit by removing the dash top & drill some holes? Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 29, 2010 Share Posted January 29, 2010 If you have a browse around there is much info on rust prevention and Waxoyling here already. Briefly access to the top of the bulkhead / A pillar can be gained by removing door hinge screws one at a time which will give access to a fine lance sprayer. You can also get in by removing the rubber grommets on the outside below the screen. The lower A pillars can be done by similarly removing door screws and if you look underneath the vehicle you should find you can also get access via the drain hole in the bottom of the pillar too. ...but like I say all this info is on the already on the forum. Quote Link to comment Share on other sites More sharing options...
q-rover Posted January 29, 2010 Share Posted January 29, 2010 I prefer these products Quote Link to comment Share on other sites More sharing options...
markpc Posted January 29, 2010 Author Share Posted January 29, 2010 Thanks everyone, I did try searching (honestly!) but couldn't get it to search for Waxoyl AND Bulkhead, it seems to always search for Waxoyl OR Bulkhead. So all the topics were really about the chassis. Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 29, 2010 Share Posted January 29, 2010 The search function is rubbish, so dont worry. Best to try searching from google with the terms waxoyl, bulkhead and lr4x4 in the query. Quote Link to comment Share on other sites More sharing options...
PaulN Posted January 30, 2010 Share Posted January 30, 2010 "The search function is rubbish" Hear Hear! Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2010 Share Posted January 30, 2010 to get waxoyl into the top areas of the bulkhead, take off the top door hinge bolts to the bulkhead & use a long lance to get in & around the front vent areas there's not much we can do about the search function, it's part of the forum software. Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 31, 2010 Share Posted January 31, 2010 there's not much we can do about the search function, it's part of the forum software. No I know, its not a problem, Google is easy enough to use, i was just pointing the OP to Google rather than have him search on here. The old software (prior to the last upgrade)seemed to have a better search facility than now. I cant get the AND, + "" or any of the old functions to work anymore on this current version. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 31, 2010 Share Posted January 31, 2010 to get waxoyl into the top areas of the bulkhead, take off the top door hinge bolts to the bulkhead & use a long lance to get in & around the front vent areas I already said that Quote Link to comment Share on other sites More sharing options...
western Posted January 31, 2010 Share Posted January 31, 2010 so you did Quote Link to comment Share on other sites More sharing options...
