Beefing Up a LR Rear Axle Casing - Pan & Pipes
Nice to see a variantion on a theme..
IMHO the routing of the std LR pipes is just asking for troubl;e, and like you I'm royally sick of damaging them, yours
is a fast and neat solution, with bnot as bad a cost as at 1st I would have thought ?
Did you get the same tight type banjo units, they look very similar - if not the same
IMVHO either Mine or TCs route makes for a vastly better solution :)
Nige
And Finally job done :)
Took a tad longer as whilst apart I twigged the wheel bearing had gone,
and 1 stub shaft, and the brake disks got changed, and the pads
and the hub seals, and the shockers too, which just added time,
but today sees it finished.
The last Fabbing job was to throw away the silly tin bracket that
holds the T piece on the top of the casing, and fab up a 4mm bracket
which fixes in the same way to the 2 x diff studs, but is stronger,
braced and has the left and right hand side protector bars join onto
to it to make for a solid protector top sides and across.
I did have a gulp when I saw the T Piece which seems to have a crack
in it <gulp> the lines where on it F tight took a lot to remove as
they had been renched and twisted just a few times :( so it may have
been getting them off that finished it, anyway new one added - check
yours maybe next time your under there ?
Anyway a few pics to show the above :
post-22-126928026462_thumb.jpg post-22-126928027867_thumb.jpg post-22-126928030639_thumb.jpg
post-22-126928032017_thumb.jpg post-22-126928033233_thumb.jpg post-22-126928035072_thumb.jpg
post-22-126928036709_thumb.jpg post-22-126928038435_thumb.jpg post-22-126928039937_thumb.jpg
And yes, I know theres a bolt missing :P
A fair bit of work, but has ciost virtaully nothing (the running repairs of disks pads etc excluded from the mods)
and I hope will once and for all sort out this issue, just need brakes bleed and nearly ready for Sunday for some "Testing"
with SLRC :)
Nige
