gazelle Posted August 9, 2010 Share Posted August 9, 2010 Just planning a clutch master replacement on a 2002 model TD5 Defender. The workshop manual states: "Fit clutch pedal sensor and pipe to master cylinder using new sealing washers" - but helpfully does not say which ones. Can anyone point me towards what I need to buy in the way of sealing washers. Is it just a number of msk100050 washers, 233220 gaskets or what do I need to get? Martin Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2010 Share Posted August 9, 2010 MSK100050 is the electrical switch/sensor 233220 is the washers that fit each side of the switch adaptor.you need 2 of these. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 9, 2010 Share Posted August 9, 2010 It's a copper washer, the same as used on the older Series UNF brake pipes Quote Link to comment Share on other sites More sharing options...
gazelle Posted August 9, 2010 Author Share Posted August 9, 2010 Cheers guys, 2 on order. Martin Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 10, 2010 Share Posted August 10, 2010 I just fitted a TD5 master cylinder to my rig (non TD5), whats the clutch sensor for? - some fangled input for the ECU? Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 10, 2010 Share Posted August 10, 2010 I just fitted a TD5 master cylinder to my rig (non TD5), whats the clutch sensor for? - some fangled input for the ECU? Yep, it's the anti-shunt system. Quote Link to comment Share on other sites More sharing options...
