Tom.H Posted August 10, 2010 Share Posted August 10, 2010 Hi A quick question: How Does the rubber used for transmission mounting compare to the rubber used for engine mounting? Transmission mount Rubber (Part number: KKB103120) http://www.lrseries.com/shop/product/listing/2913/KKB103120-MOUNTING-RUBBER.html?search=mounting%20rubber&page=1 Engine mount Rubber Part number: ANR1808 http://www.lrseries.com/shop/product/listing/2870/ANR1808-ENGINE-MOUNTING-RUBBER.html?search=ANR1808&page=1 I only ask because I’ve completely ‘re done’ the engine mount brackets on my vehicle. They used to use the rubber from radius arms bushes and not surprisingly they didn’t absorb much of the vibration. The bracket I now have allow me to use normal engine mount rubber used on rover V8 and TDI’s I thought there would be a vast improvement in vibration however there isn’t. I picked out the mounts I used from a box of gearbox/engine mounts. Basically there might be a possibility I’ve used transmission rubber instead of engine mount rubber, as they both look familiar Does anyone know if the transmission rubber is stiffer than engine mount rubber? Could this the possible reason why there is no improvement in the vibration going through my vehicle? Old mount New mount Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 10, 2010 Share Posted August 10, 2010 As far as I know the rubber type is identical, just the pad area of the bushes. - how bad is bad vibration? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted August 10, 2010 Share Posted August 10, 2010 Where are your replacement mounts from? There has been some discussion on here along the lines of the pattern parts being harder than the genuine LR items. Quote Link to comment Share on other sites More sharing options...
Tom.H Posted August 10, 2010 Author Share Posted August 10, 2010 The Vibration is quite bad. After replacing the mount I notice that the transfer box was pushed against the chassis. With it now moved away there is an improvement however I still think it’s no way as smooth as a normal land rover 90 I don’t know where the mounts are from. They aren’t new and were basically picked out from a box of odd mounts. The reason I didn’t start off with new ones is because they were left in when the brackets were welded onto the chassis and I thought they would have melted They don’t seem to have become damaged from being welded however I am up for replacing the mounts with new ones. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2010 Share Posted August 10, 2010 Microcat shows rubber mount KKB103120 for V8 4.0 ltr engines only, for 200Tdi & gearbox you need ANR1808, got these on my 200Tdi/R380 110 no vib problems with them. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 10, 2010 Share Posted August 10, 2010 I got new ANR1808s a while back to put under my transmission, and the vibration was very bad to begin with. It has now got a lot better (I imagine the rubber has stretched/softened with the movement), but next time I will use Genuine to be sure Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted August 10, 2010 Share Posted August 10, 2010 I got new ANR1808s a while back to put under my transmission, and the vibration was very bad to begin with. It has now got a lot better (I imagine the rubber has stretched/softened with the movement), but next time I will use Genuine to be sure I would agree. I had to use Sh!tpart, as I was on a deadline for an MOT, and they were definitely pretty hard, but I would say they've softened up a bit. Given the chance, I'd buy genuine. Quote Link to comment Share on other sites More sharing options...
zardos Posted August 10, 2010 Share Posted August 10, 2010 Hi A quick question: How Does the rubber used for transmission mounting compare to the rubber used for engine mounting? Transmission mount Rubber (Part number: KKB103120) http://www.lrseries.com/shop/product/listing/2913/KKB103120-MOUNTING-RUBBER.html?search=mounting%20rubber&page=1 Engine mount Rubber Part number: ANR1808 http://www.lrseries.com/shop/product/listing/2870/ANR1808-ENGINE-MOUNTING-RUBBER.html?search=ANR1808&page=1 Having an ANR1808 in front of me, the Engine mounts are:- metal disc | rubber | metal disc | rubber | metal disc The transmission mounts are:- metal disc | rubber | metal disc And from memory the Transmission mounts offer slightly more flex, but I still rip either type from the mountings as my engine tries to escape Quote Link to comment Share on other sites More sharing options...
