farmer_ben Posted September 13, 2010 Share Posted September 13, 2010 hi I've got a 1986 110 and would like to know if a series 1 descovery front prop will fit???? any help would be aprechiated! many thanks,ben Quote Link to comment Share on other sites More sharing options...
western Posted September 13, 2010 Share Posted September 13, 2010 different part numbers, so probably won't fit, but might be worth comparing both side by side to check. Quote Link to comment Share on other sites More sharing options...
Briarston Posted September 13, 2010 Share Posted September 13, 2010 different part numbers, so probably won't fit, but might be worth comparing both side by side to check. Wrong length for a "90", assuming engine/box/front axle is in the same position as a 110. I tried it. Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted September 13, 2010 Share Posted September 13, 2010 Be aware that it's not just a case of whether they will fit when the vehicle is sitting still. They also have to still fit when the suspension is at maximum and minimum extensions while moving at speed. The consequences of them being too long or short in these circumstances should be obvious! Nick. Quote Link to comment Share on other sites More sharing options...
jbs Posted September 14, 2010 Share Posted September 14, 2010 When I was doing the uj's on a friends of mine's 300 tdi disco I found that the front prop had a different size uj on one end and then looked at what would fit in my garage-I found one of the prop's off of my 200 tdi 90 fitted it-this means now that when i get to do the job again I'll be able to fit normal 90/110 uj's onto that prop, the only downside to the disco set up is it still has that damned doughnut on the back end of it which luckily I replaced with a decent make of one (can't remember which make now ) so that will hopefully last out the rest of it's days seeing as she only uses it for dragging horses about and daily driving HTH John Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 14, 2010 Share Posted September 14, 2010 disco/rangey front props will fit 300/td5 90/110's, but not the earlier trucks as the engine sits further back and the prop is longer. I suspect JBS has found that a 200tdi 90 REAR prop fits the front of a disco, however its 15mm shorter than the proper item, and isnt phased correctly to run on the front axle, so thats not really a good idea. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted September 14, 2010 Share Posted September 14, 2010 There have been changes to things like the seal/boot on the slip joint, also a couple of different uni-joint sizes have been used in some models, so changing either of those would involve a different part number for the prop shaft. But those may not necessarily prevent interchange. The important thing is to have the correct closed and open length, and substituting a narrow yoke when a wide yoke is required could give problems (vibration or binding on maximum suspension droop). AFAIK the flange details (bolt centres, spigot diameter) were not changed (except t/case end of disco II). I haven't compared those particular prop shafts directly so don't take this post as a yes you can without a proper comparison. Quote Link to comment Share on other sites More sharing options...
