12v element for removing sump plug
hattymender
Called to see a friend who was struggling to get the sump plug out of an old Mondeo. They have a small 10mm head but the bolt body's about 14mm, the sump's aluminuim. And it was well stuck.
I headed for stilsons (nice big ones), he stopped me and headed for camping kit and produced one of those 12v 'drop in cup' heaters (looked suspiciously bent to get element to sit flat on sump, must have done this before). Plugged it in, held it against sump for a few minutes with aid of welding glove and 'hey presto' out came the plug with a slight tap on a10mm spanner. Simples!
Obviously heat expanded aluminium sump faster than steel plug and broke the hold on the thread. 12v element doesn't push out enough heat to melt the alloy. Probably.
Learn something every day?
A bit like a block heater?
http://www.google.co.uk/url?source=imgres&ct=img&q=https://www.chevygmparts.com/images/block_heater.jpg&sa=X&ei=HIrxTIWwO4K14gaJiaXIAQ&ved=0CAQQ8wc4GQ&usg=AFQjCNG98rW5YMB8wZAQq70JtxB6QCrdVA
They exist for 2.25 petrols: http://www.roversnorth.com/store/p-14478-freeze-plug-block-heater-series-ii-iii-225p.aspx
Never found any for other LR engines, although if the core plug hole was the same size and there was space internally then any block heater would work :)
