nino Posted January 14, 2011 Share Posted January 14, 2011 as with all forums theres lots of people who ask and give advice on problems what i want to know how many of you have problems that you know of but cant be bothered to fix or not on the list of things that need fixing or anything else? my offroader has many faults that i know of but dont bother me or can be done some time soon the faults and problems are 1, the wipers do a full sweep when they like when in the off position 2, my osr spring comes away from the chassis when the axle is on articulation be playdays or green lanes and dont find its way back in the cup propley nothing wront with the nsr tho?? 3, prop uj' have now got too much play in them that greese only fixes for a day or so 4, major rear diff pinion play resulting in all sorts of knocks bangs and milkshake being found where oil should be, oil gets changed every few weeks till i get it sorted tho lol 5, ns door handle still broken so cant open from the outside 6, os door opening is done by a cable tie as the window got stuck open by 2" about 2 months ago and only just got it fixed as the way i closed the door was crab the bottom of the window and it worked loose and the tape didnt hold any more 7, about 20 holes in the rear where old bench seats and seat belts were removed and more holes were drilled to fit a single fold up seat either side 8, im sure i have a few bushes that have play in them as theres knocks and bangs when hitting bumps in the road 9, theres a creaking where the side and tub meet on the capping, only get this onge it had been jetwashed so not that oftern 10, hrw not working as the terminal has been broken off the window 11, rear wash wipe not working as i dont know where the wires are for it up front 12, all guages mist up after a wile 13, diff lock light not working rite i think thats it, but like i said these things dont bother me nor are of importance at the moment the first job to do is get the diff and props sorted as i tend to do a fair amount of miles in it and i have the parts to do the jobs as well so there shouldnt be any excuse realy now itd down to you wot problems hav u got that u can deal with and not worry about? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 14, 2011 Share Posted January 14, 2011 Let's see, in the 90.... Need to install heated rear window and rear wiper. Need to paint rear sides and back door. Wiper switch slightly intermittent on intermittent, as it were. Still trying to sort the persistent leak into the footwells from the bulkhead corners. Small leak from rear diff pinion seal. Small leak from transfer box front output seal, and slight play in bearing (think the play is normal though). Oil leak from the engine somewhere, ends up dripping off the sump plug. Radio aerial loose in mount, rattles around. Rear door needs adjusting, the lock comes undone (onto the semi-locked position) on bumpy roads. Gearbox cross-member banana-shaped. Headlights slightly corroding inside. Electric fan thermostat knackered, to be replaced with x-fan before summer. Rear headlining to find/fit. Back end needs some sound deadening/proofing. Think that's about it, probably forgotten a few things. Quote Link to comment Share on other sites More sharing options...
JeffR Posted January 14, 2011 Share Posted January 14, 2011 The Forth Road Bridge Family Hack needs the following: Headling put back in Sunroof removed and re-sealed Oil leaks fettled (might give up on those) Exhaust manifolds need taken off, thrown away and new ones aquired/fitted Pad chatter on rear discs need sorted Wiring..... Instrument binnacle needs replaced 10 Cd autochanger need fitting Sort out why instruments are all full of water Replace rear door (new one been in garage for a year) Replace body cappings rebuild carbs Sort out major bodywork dings Paint the bugger Replace floor in front of second row seats Replace rear window seals to stop the buggers rattling Sort out some form of soundproofing Find out why speakers have got so much interference on em Get gas conversion up and running plus whatever I find doing that lot! Quote Link to comment Share on other sites More sharing options...
Phillis Posted January 14, 2011 Share Posted January 14, 2011 umm... Heater motor Cold/hot select cable New rear numberplate as its cracked and mot soon sort wipers out sort my air filter and the breather pipe Rockercover gasket needs replacing put bolts on seats put a electric fan on sort temperature guage plumb boostguage in clean my windscreen from the blood and grime from mucky fingers get a snorkel so i can wire my spots in i thinks theres a few more on my list but thats it for now. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 14, 2011 Share Posted January 14, 2011 Top of the list is my lights need fixing! Fit new front prop and hopefully cure clunk by doing so. Fit hydraulic reservoir, solenoid and pipe work Stop X -brake pads rattling Fit 12v point in dash Move CB Waxoyl chassis Fix a small coolant leak Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 14, 2011 Share Posted January 14, 2011 Rear wiper and heated window needs wireing in Once wipe doesn't work It needs painting all the same colour Need new windscreen seal Electric cooling fan to fit Tow ball to fit Winch to fit a wire up Boost heater to wire up Rear utility light to fix Intermittent reversing light Oil leak from lift pump Extra bolt needs putting in bell housing The list goes on... Quote Link to comment Share on other sites More sharing options...
nino Posted January 14, 2011 Author Share Posted January 14, 2011 so there are a few out there that need things doing but cant be bothered lol glad im not the only one, saying that im having a landrover (and other 4x4) tinkering weekend so i hope to get some bits done to mine and not just help out others that are joining me at work lol, the biggest job of the weekend is to fit a engine to a mates 90 and hope to get it in running and most of the car put back together as he got a petrol 90 off ebay somr tiame ago and he goin to stick in a 200tdi, weve dun things like this before so it shud go well lol Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 14, 2011 Share Posted January 14, 2011 I'm not going to list the faults with mine because I don't want to take up too much space on the server. Quote Link to comment Share on other sites More sharing options...
skint Posted January 14, 2011 Share Posted January 14, 2011 so there are a few out there that need things doing but cant be bothered lol glad im not the only one, saying that im having a landrover (and other 4x4) tinkering weekend so i hope to get some bits done to mine and not just help out others that are joining me at work lol, the biggest job of the weekend is to fit a engine to a mates 90 and hope to get it in running and most of the car put back together as he got a petrol 90 off ebay somr tiame ago and he goin to stick in a 200tdi, weve dun things like this before so it shud go well lol Hope thats not a bit of jap scrap getting fixed we are going to be busy Quote Link to comment Share on other sites More sharing options...
