potato head Posted March 17, 2011 Share Posted March 17, 2011 Tomorrow I'm planning on putting some heat on my gearstick and bending it away from my centre console and cb Mic cable. It's going to be done off vehicle but having just removed the gator and looking at the stick, I'm wondering what issues, if any I will come across by doing this as the stick seams to be mounted into some sort of rubber inside the selector piece that has the 17mm af but on. For anyone that's had to do this did you bend the stick or add more bend to the bottom near the nut? Quote Link to comment Share on other sites More sharing options...
jad Posted March 17, 2011 Share Posted March 17, 2011 can you not just take the nut off, take the gearstick off and rotate it round so it leans further away from the centre console? Quote Link to comment Share on other sites More sharing options...
max-ie Posted March 17, 2011 Share Posted March 17, 2011 Put the rubber end in a bucket of water whilst you heat the section your bending.... bend it and then cool it all down in water so nothing melts. Quote Link to comment Share on other sites More sharing options...
Russell_ds80 Posted March 17, 2011 Share Posted March 17, 2011 My old man put a few bends in his rangerover one. works fine. Quote Link to comment Share on other sites More sharing options...
potato head Posted March 17, 2011 Author Share Posted March 17, 2011 It's already at its best position after rotation. I think what I may do it to part cut the lower stem in the middle and then bend the stem to the best position and then re-weld the cut up. This way I can get it into it's best angle without using any heat. Quote Link to comment Share on other sites More sharing options...
jad Posted March 17, 2011 Share Posted March 17, 2011 welding = heat....... Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted March 17, 2011 Share Posted March 17, 2011 welding = heat....... that tickled me Quote Link to comment Share on other sites More sharing options...
crclifford Posted March 17, 2011 Share Posted March 17, 2011 Just ask nige!!! Quote Link to comment Share on other sites More sharing options...
potato head Posted March 17, 2011 Author Share Posted March 17, 2011 Ok a little heat yeah but welding heat is a lot less and more localized than the heat produced by a oxy torch Quote Link to comment Share on other sites More sharing options...
TS888 Posted March 18, 2011 Share Posted March 18, 2011 I was pondering this same issue. On the R380, the lever is mounted on an offset that puts it in front of the splined shifter stub on the box. I'm thinking of cutting the shift lever and reversing the offset so it is to the back of the splined stub. The shifter would fall nearer to hand as well as clearing the dash and Raptor console by an extra couple inches. Of course I have no center seat. If you do, this might make things a bit personal for any center seat occupants... Quote Link to comment Share on other sites More sharing options...
