simonb Posted July 16, 2006 Author Share Posted July 16, 2006 yep I'm aware of that, what I meant was that I turn the key and it started before the plugs had a chance to warm - if they were working Quote Link to comment Share on other sites More sharing options...
white90 Posted July 16, 2006 Share Posted July 16, 2006 they glow red hot within 3secs as soon as you turn the key to try and start the vehicle. mine had a brand new battery and still failed to start until I changed the plugs. normal service will resume I bet as soon as new ones are fitted. Quote Link to comment Share on other sites More sharing options...
western Posted July 16, 2006 Share Posted July 16, 2006 Glowplugs & timer will operate regardless of whether you wait for the light to go out or not. Quote Link to comment Share on other sites More sharing options...
simonb Posted July 16, 2006 Author Share Posted July 16, 2006 Well just got a set of Eblag as recomended by Western. We will all find out later in the wk. They might even reduce the puff of black smoke on starting its always had, since now the diesel should be combusting better on start up. Quote Link to comment Share on other sites More sharing options...
western Posted July 16, 2006 Share Posted July 16, 2006 Well just got a set of Eblag as recomended by Western. We will all find out later in the wk. They might even reduce the puff of black smoke on starting its always had, since now the diesel should be combusting better on start up. Done well there, got for a good price Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted July 16, 2006 Share Posted July 16, 2006 I tried to stay out of this thread due to the fact that is about stinkin 4 pot oil burning fat fryers But ……….. all the bad starting derv engines I have worked on with those symptoms , it has always been a glow plug problem. I found with the son’s 300tdi. that even 2 plugs not working were enough to give it the ‘cough & fart’ start. Ian Quote Link to comment Share on other sites More sharing options...
white90 Posted July 16, 2006 Share Posted July 16, 2006 funny if you read page 1 of this thread you wouldn't have thought so Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 16, 2006 Share Posted July 16, 2006 stinkin 4 pot oil burning fat fryers Watch it sunshine!! Les, Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted July 16, 2006 Share Posted July 16, 2006 Watch it sunshine!! Les, Listen sunbeam, Catflap deserves a decent engine instead of an asthmatic diesel ……………. A Corvette LS6 will go nicely in there……. B) Ian Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 16, 2006 Share Posted July 16, 2006 Well if you're giving one away - who am I to look a gift HORSE in the mouth Les. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted July 17, 2006 Share Posted July 17, 2006 Les, The LS6 certainly isn't short on horses ! Ian Quote Link to comment Share on other sites More sharing options...
white90 Posted July 19, 2006 Share Posted July 19, 2006 Well just got a set of Eblag as recomended by Western. We will all find out later in the wk. They might even reduce the puff of black smoke on starting its always had, since now the diesel should be combusting better on start up. Any outcome yet? Quote Link to comment Share on other sites More sharing options...
simonb Posted July 19, 2006 Author Share Posted July 19, 2006 Not arrived yet, were dispatched 2day but i'm off to the Farnborough Airshow 2moz , so probably won't get round to it till the wknd. Bit too hot for spannering without any shade at the moment. The series 3 rebuild this wk only takes place between 7am and noon cos its too hot, but thats another story. No more no starts since last fri am - but in this heat its not surprising.. Quote Link to comment Share on other sites More sharing options...
LR90 Posted July 19, 2006 Share Posted July 19, 2006 Good thread. I've learnt something new and good on Tony for being on the ball. (Assuming is does actualy fix the problem of course ) Quote Link to comment Share on other sites More sharing options...
simonb Posted July 21, 2006 Author Share Posted July 21, 2006 New glow plugs are in. Checked on battery b4 fitting. Confirmed they are working in situ by watching voltmeter, when relay clunks off, volts go back up to 14v from cranking voltage. Smaller black "chuff" of smoke on starting than b4, seems initial idle after starting is less lumpy as well. Hopefully no more no starts, hadn't had any this wk since I found the plugs were duff last wknd - didn't even bother putting the wiring back on last Sat.. Quote Link to comment Share on other sites More sharing options...
simonb Posted August 28, 2006 Author Share Posted August 28, 2006 Well was never conviced it was the glow plugs - 2 wks after fitting them, the no starts returned. Had fitted a new stop solenoid by then as well, so it wasn't that. Anyway decided to fit a new lift pump.... Touch wood, been fine since (over a month now), idle seems smoother as well. Starts no problems even if left for a few days with the fuel level down to the orange on the gauge. Guess the pump had a leaky valve and that combined with which part of the stroke it stopped on, allowed the fuel to run back to the tank, hence all the cranking to get it going. Quote Link to comment Share on other sites More sharing options...
