Serpentine V8 water temp sender connection
task
I have a serpentine Rover V8 with hotwire EFI. As fitted to Softdash Range Rover Classics and to facelift Discovery 1's.
The water temp sender (mounted front right of the inlet manifold) has a rather interesting connection that I don't seem to have a connection for. Anyone know what it is or, even better, where I can find one?
Thanks
I tried bullet connectors but the peg is a smaller diameter so it doesn't make contact. I tried adjusting the connection with some pliers but it just popped off :(
it looks like this;
and feeds the gauge. I believe it may also be used for 300 tdi's too.
You could easily use one standard pvc terminal block like one of these.
http://www.autoelectricsupplies.co.uk/product/49/category/116
Check for correct size.
I had thought about that, and it might do for a quick fix, but I'd rather it look proper in the long run. I may resort to emailing breakers to see if anyone can chop that bit off a loom for me :)
