range17 Posted December 14, 2011 Share Posted December 14, 2011 Hi all ,has anyone any ideas why my 200tdi is lumpy and missfires when cold but is fine when warmed up ! could it be the injector pump do they have a (cold start setting) Quote Link to comment Share on other sites More sharing options...
RILEY Posted December 14, 2011 Share Posted December 14, 2011 Tickover to low ? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 14, 2011 Share Posted December 14, 2011 What fuel? On pure DERV mine shows occasional small symptoms as you discribe, on SVO, WVO or Bio its quite regular...I put it down to lack of fuel until there's a little bit of warmth there...the hand throttle comes into its own. Quote Link to comment Share on other sites More sharing options...
range17 Posted December 14, 2011 Author Share Posted December 14, 2011 What fuel? On pure DERV mine shows occasional small symptoms as you discribe, on SVO, WVO or Bio its quite regular...I put it down to lack of fuel until there's a little bit of warmth there...the hand throttle comes into its own. The fuel is normal diesel ,i have completely rebuilt the engine recently ,new pistons rebore ,camshaft ,camshaft bearings ,tappet assemblys etc . After a while i adjusted the valve clearances and that is when it started to (cough and misfire ) when cold untill warmed up . Quote Link to comment Share on other sites More sharing options...
range17 Posted December 14, 2011 Author Share Posted December 14, 2011 Tickover to low ? Tickover seems to be fine when warm though . Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted December 14, 2011 Share Posted December 14, 2011 Could be a leaky injector or possibly low compression on one cylinder, although that is unlikely to be the case if you have fitted new rings correctly. But you may have a leak in the head gasket? Check the clearances again though as it was fine before you did them. It's probably something simple like that. Quote Link to comment Share on other sites More sharing options...
range17 Posted December 14, 2011 Author Share Posted December 14, 2011 Could be a leaky injector or possibly low compression on one cylinder, although that is unlikely to be the case if you have fitted new rings correctly. But you may have a leak in the head gasket? Check the clearances again though as it was fine before you did them. It's probably something simple like that. Have got another set of injectors in at mo and no change ,rechecked the clearances they were fine ,thinking of backing them of slightly because they all needed adjusting up a bit which produced the cough come missfire when cold , Wondering if the injector pump has a problem when cold ?? Quote Link to comment Share on other sites More sharing options...
muddy Posted December 15, 2011 Share Posted December 15, 2011 Quite a few Defnder 200 TDis i know of do this when cold, and my 300 wich has never done it did it the other morning briefley when i started it in the cold without giving the glowplugs time to warm. I wouldnt worry about it if it only does it in the cold, alot of perkins engines i have used also do this, many advise to hold the key in the 'heat' position until the engine runs smoothly. Will. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 15, 2011 Share Posted December 15, 2011 My 200Tdi was like that. Even changing the injectors made no difference. I just lived with it. We couldn't find a clue when the head came off either. Quote Link to comment Share on other sites More sharing options...
Lorrick Posted December 15, 2011 Share Posted December 15, 2011 I would re check the valve clearances if it started just after you adjusted them ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 16, 2011 Share Posted December 16, 2011 i adjusted the valve clearances and that is when it started If only there was some sort of clue as to what the problem could be. Nope, I'm stumped. Quote Link to comment Share on other sites More sharing options...
range17 Posted December 16, 2011 Author Share Posted December 16, 2011 If only there was some sort of clue as to what the problem could be. Nope, I'm stumped. S0 if it is the fact i have set the valve clearances to exactly the right clearance ,why would that make it lumpy ,an answer to the problem would be good instead of quoting something i have already said . Quote Link to comment Share on other sites More sharing options...
