henk Posted December 16, 2011 Share Posted December 16, 2011 As I want to put 2 alternators on a 200tdi, will a V8 crankshaft bottom pulley fit on a 200tdi? Henk Quote Link to comment Share on other sites More sharing options...
zardos Posted December 16, 2011 Share Posted December 16, 2011 Best to speak to Gwyn Lewis as they do twin alternator mounts like (http://www.gwynlewis....uk/page80.html) Though this only shows the 300tdi version, he also does V8 (I have one) and 200 tdi versions I believe. Quote Link to comment Share on other sites More sharing options...
henk Posted December 16, 2011 Author Share Posted December 16, 2011 I just need the double pulley, all the rest I make myself Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 16, 2011 Share Posted December 16, 2011 I've had a double pulley for a 200TDi disco on order with Buckley for nearly 12 months now, still no sign of it. If it gets to 12 months I'll be cancelling it, they've made no effort to contact me to keep me updated, and I only found it they had it on order when I enquired after a month as to why it hadnt arrived Quote Link to comment Share on other sites More sharing options...
Les Brock Posted December 16, 2011 Share Posted December 16, 2011 I went into the main stealers one was there in two day around £25.00 IIRC this was about 2 years ago so not 00% sure now but it was'nt dear ! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted December 16, 2011 Share Posted December 16, 2011 2.5na and td pullies will fit on a 200 crank damper Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 17, 2011 Share Posted December 17, 2011 hmmm...think I've still got my TD's pulley...think it was even a double, in fact it must have been, for the PAS... Quote Link to comment Share on other sites More sharing options...
poohbear Posted December 18, 2011 Share Posted December 18, 2011 Have you got air-con? I managed to destroy my 200tdi crank pulley trying to remove it, replaced with a brand new one (which was relatively cheap - just don't look at prices for the damper!). I ordered an air con one ready for on board air set up, but you could use this to drive a 2nd alternator instead. as far as I recall - all the pulley variants fit onto the damper. Dave Quote Link to comment Share on other sites More sharing options...
western Posted December 18, 2011 Share Posted December 18, 2011 double groove pulley was used for alternator/water pump & PAS pump, a 3 groove pulley as fitted to air cond fitted vehicles/engines might be better, these have the crank/PAS belt in forward groove crank/water pump/alternator in the centre groove air cond pump/crank in rear groove. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted December 18, 2011 Share Posted December 18, 2011 double groove pulley was used for alternator/water pump & PAS pump, a 3 groove pulley as fitted to air cond fitted vehicles/engines might be better, these have the crank/PAS belt in forward groove crank/water pump/alternator in the centre groove air cond pump/crank in rear groove. air con is on the middle groove Ralph. Quote Link to comment Share on other sites More sharing options...
western Posted December 18, 2011 Share Posted December 18, 2011 darn, I should have checked the photo's of my Defender 200Tdi crank pulley [added below] well spotted, just to correct my previous reply crank/PAS belt in forward groove air cond pump [if fitted] /crank in centre groove. crank/water pump/alternator in the rear groove Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 18, 2011 Share Posted December 18, 2011 Just a thought, but are we talking defender here? or disco? Isnt disco Air-con (where fitted) on rear or pulleypulley, crank/pump/pas front of pulley? (only 2 grooves) Quote Link to comment Share on other sites More sharing options...
western Posted December 18, 2011 Share Posted December 18, 2011 Defender or Discovery 200tdi wasn't specified, by the OP. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 18, 2011 Share Posted December 18, 2011 Hence my question... Quote Link to comment Share on other sites More sharing options...
farmerboy_y2k Posted December 18, 2011 Share Posted December 18, 2011 My 200tdi only had a single pulley till recently. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted December 19, 2011 Share Posted December 19, 2011 Just a thought, but are we talking defender here? or disco? Isnt disco Air-con (where fitted) on rear or pulleypulley, crank/pump/pas front of pulley? (only 2 grooves) disco's have 1 or 2 belt crank pullys due to the alt being driven from the pas pump. Yes, its most likely the qircons driven from the rear pully. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 19, 2011 Share Posted December 19, 2011 Yes it is, checked this morning. Also, found my TD pulley, and it does indeed look like it will fit the disco engine however! It is a two groove pulley, for PAS (front groove) and waterpump/alternator (rear pulley)...which means, you can't put it on a disco 200, otherwise you'd be able to drive the aircon (rear) but not the water pump - you'd need the missing middle pulley. If you wanted a TD pulley to fit on a disco 200, you'd need the 3-groove air con version. Quote Link to comment Share on other sites More sharing options...
henk Posted December 21, 2011 Author Share Posted December 21, 2011 Defender or Discovery 200tdi wasn't specified, by the OP. Defender 200tdi. It has a double pulley now but looking for the 3 groove one. Am I correct it is partnr ERR3093? Quote Link to comment Share on other sites More sharing options...
western Posted December 21, 2011 Share Posted December 21, 2011 Defender 200tdi. It has a double pulley now but looking for the 3 groove one. Am I correct it is partnr ERR3093? Correct new one here if you can't find a good 2nd hand item. Quote Link to comment Share on other sites More sharing options...
poohbear Posted December 22, 2011 Share Posted December 22, 2011 that's the one I got - Fits fine on my defender 200Tdi along with a damper robbed off a disco 200Tdi - Just need to tap the timing case to take the sanden now! Dave. Quote Link to comment Share on other sites More sharing options...
