Erratic Idle Speed (RV8 4.6)
stuck
Gents,
My 4.6 110 is booked in for it's MOT on Friday, the only thing I'm a little worried about is the emissions check (assuming this is carried out at idle speed) even though I have a MOT friendly map as supplied by Nige.
Even when warm (IIRC this is defined as 68 degrees within MT) my truck's idle speed is bouncing between 700 & 1200 RPM & occasionally as high as 1400 RPM.
The "slow idle speed" is set at 880 RPM so is this just a case that my idle speed is set too low mechanically or am I missing something?
Cheers for your patience,
Mick.
If you just turn it off, the idle valve remains open (a bit). You have to mechanically blank it to completely disable it.
Yeah I said disable it, not unplug ;)
Set the duty cycle to a fixed...25 IIRC is closed, and it won't open or close.
Tuning closed loop idle can be a PITA, especially on an auto.
