LT85 whine - what causes it? Also is there a reduced throw shifter?
On a factory V8 90 with the standard LT85 5 speeder, when you rev it you get a whine sort of sound from the transmission. It does this either with the clutch in or out, although maybe a slightly different tone/sound. And also while driving.
I don't think it's a problem as the vehicle has been known and/or in the family since around 2002 and goes fine, but I wouldn't mind knowing the cause of the noise and if anything can be done to reduce or curer it?
And while I accept the LT85 will always feel more agricultural than an LT-77/R380, is there anything you can do to reduce the amount of throw/movement needed to change gear, or indeed make it feel more like an LT-77 in operation? Some sort of "quick shifter" linkage or similar?
Thanks.
Haha, unfortunatley a long throw and much noise are the price you pay for the good ol' LT-85... They're hard on their bearings, the helical cut gears cause the gear cluster to crash forward into the front of the box under load, that's a lot of thrust for the input shaft bearing to handle. You can rebuild with up-rated bearings to help cope with it. If you have a split-case model, you have an advantage during the rebuild process.
Ray.
As Ray said ^^^
The mainshaft bearings are the source of the noise, they don't seem to stay quite for long, even after a rebuild. The bearings are huge in size and huge in price too.
I rebuilt my solid case LT85, not too difficult but you do need some special tools to remove/fit bearings to the shafts.
If you are used to handling LT77s you had better have an extra Weetabix for breakfast before tackling an LT85 :lol:
I wonder what difference modern synthetic lubricants would make to the running of this 'box? Of course you'd have to use something the oil pump is happy with.
I run Redline Mt oil in my 110 V8 CSW , have done for years , works well , and the box has done some very hard work , eg towing over 3.5 tonnes in 45C and a maximum of 54tonne in one instance . the main box seems quiet enough but the transfer gets a bit whiney esp over 70 you can just about hear it over the tyres , but its always been like that . I dont see how you can shorten the throw of the gear lever other than by cutting something off the top, as you are moving some quite large gears , in a gearbox with a tall top . They obviously put the dog leg in it to stop it hitting the dash ! JMHO
