Quagmire Posted April 29, 2012 Share Posted April 29, 2012 Does anyone have any tips on getting the bottom nuts on the front shockers? I dont have quite enough thread to get the nut started and so need to compress the bottom most bush somehow... Any tips? Cheers Quote Link to comment Share on other sites More sharing options...
stuck Posted April 29, 2012 Share Posted April 29, 2012 Can't you Jack the axle up a bit? That's what I've always done. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 29, 2012 Share Posted April 29, 2012 Ah yes, not enough thread... What I did was to fit an old bush then take it out and put the new one in a couple of days later. That allows the other bush to compress a bit. Quote Link to comment Share on other sites More sharing options...
Boris113 Posted April 29, 2012 Share Posted April 29, 2012 Had this problem with my rear pin-pin shocks the other day, lots of pissing around with a jack and hanging off the shock had the nut on eventually. Harry Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 29, 2012 Share Posted April 29, 2012 Use decent shocks.. I've never had this problem with vehicles when fitting decent shocks. Quote Link to comment Share on other sites More sharing options...
NickMc Posted April 29, 2012 Share Posted April 29, 2012 Undo the turret so you can put it in at an angle Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 30, 2012 Share Posted April 30, 2012 Use decent shocks.. I've never had this problem with vehicles when fitting decent shocks. So why don't you think Land Rover Genuine parts aren't decent ? LOL Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 30, 2012 Share Posted April 30, 2012 So why don't you think Land Rover Genuine parts aren't decent ? LOL Because they have a Land Rover badge on..... I've fitted Koni's, Armstrong and Terrafirma shocks to different Land Rovers and never struggled with getting the bushes and nuts on. The terrafirma shocks bottom pin is very long i've seen bottom pins bent because they've hit the axle case. Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 30, 2012 Share Posted April 30, 2012 See if you can get some pliers on the shock through the spring and force it down, if needed with some help from a mate. Also check that both bushings are correctly seated. Quote Link to comment Share on other sites More sharing options...
