mcc1979ian Posted July 4, 2012 Share Posted July 4, 2012 Evening all, im thinking of having an on-board air supply in the 90 but have gave myself 2 options, 1. use air con pump and convert and rig up to a tank 2. iv changed to coils on the back of the disco so now have a redundant compressor on here i could use question is which do you think would be the best option and what would i all need to make the disco compressor idea? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 4, 2012 Share Posted July 4, 2012 What do you plan to use it for? Inflating tyres or running powertools and so on.... Quote Link to comment Share on other sites More sharing options...
ejparrott Posted July 4, 2012 Share Posted July 4, 2012 do you know what the output of the D2 compressor is like? AirCon pumps are said to be very hi flow, i haven't got mine up and runnning yet, the belt i bought didn't seem to be long enough... Quote Link to comment Share on other sites More sharing options...
martifers Posted July 4, 2012 Share Posted July 4, 2012 Check out the tech archive Ian, are a few write ups there i.e http://forums.lr4x4....?showtopic=2115 , and http://forums.lr4x4.com/index.php?showtopic=13723 Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 6, 2012 Share Posted July 6, 2012 Don't use the air suspension compressor, they're not made to handle airing up tyres and such. They can give a lot of pressure, but have a pretty low duty cycle. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 6, 2012 Author Share Posted July 6, 2012 just plan on inflating tyres and running tools. may have a good read of them write ups and see about using the air con pump as its not gona be used for air con Quote Link to comment Share on other sites More sharing options...
tacr2man Posted July 8, 2012 Share Posted July 8, 2012 The aircon pump will give you all the air you need esp with a old CO2 fire extinguisher or such like as a tank You will need suitable high pressure/hot temp hose , a inline oiler if using for power tools etc . safety valve , and a pressure cutout switch in the power feed . Quote Link to comment Share on other sites More sharing options...
zim Posted July 8, 2012 Share Posted July 8, 2012 You can't effectively run tools (impact wrench, drill etc) from an air con pump in my opinion. Sorry. (yes i have a tank). G Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 8, 2012 Share Posted July 8, 2012 You can't effectively run tools (impact wrench, drill etc) from an air con pump in my opinion. Sorry. (yes i have a tank). G Turn your idle up.... Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted July 8, 2012 Share Posted July 8, 2012 You can't effectively run tools (impact wrench, drill etc) from an air con pump in my opinion. Sorry. (yes i have a tank). G Why not? I have a 10 litre tank on mine and the rattle gun will happily knock the wheel nuts off. If you need a bit more air, just wedge a stick on the throttle! Quote Link to comment Share on other sites More sharing options...
