Hybrid_From_Hell Posted July 8, 2012 Share Posted July 8, 2012 Yes I have done a search BUT I am trying with mate to wire up the new engine and its alternator, and am stuck ! Unit is a DRA3676 poss a Reme Delco ? It has 3 x terminals on the back 1 x Big one - (see piccie on the Left Hand Side) Middle has a little stud and a 3rd on the right It looks like some of the plastic has broken off from the edge of the big terminal on the Left, but there is a D+ to the right of the big terminal, then W to the right of D+ and thats it ! HELP What goes where ? Nige Quote Link to comment Share on other sites More sharing options...
TSD Posted July 8, 2012 Share Posted July 8, 2012 Right hand small terminal will be W, the rev counter feed. Middle terminal D+, pre-excitation circuit (in other words, the warning lamp feed) Big terminal is B+, main feed to the battery (and if you didn't figure that one out Nige, you really should get a grown up to help!) EDIT : And you didn't search very hard, the second link on Google after searching for the part number you listed contains :- Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 8, 2012 Share Posted July 8, 2012 I would say left hand big one is B+ charge output (for battery connection), middle is D+ for warning light connection and the right is the W terminal for rev. counter (if fitted). Edit: TSD types faster than me! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 8, 2012 Author Share Posted July 8, 2012 I have a grown up doing me wiring Ican't be trusted with eletrwics Nige Thanks all Quote Link to comment Share on other sites More sharing options...
Jon White Posted July 8, 2012 Share Posted July 8, 2012 Nige B - battery positive D - warning light Do not use W terminal - this is used for rev counters on diesels. Yours wasnt diesel the last time i looked, so take your tacko feed directly from the edis unit where it is already. Jon Quote Link to comment Share on other sites More sharing options...
western Posted July 9, 2012 Share Posted July 9, 2012 might help Quote Link to comment Share on other sites More sharing options...
