sharkey964 Posted September 7, 2012 Share Posted September 7, 2012 I have an anoying vibration on my 110 300tdi. I bought the truck about 4 months ago and it's been doing it since day 1.I was very worried at first because when I picked it up I had a 800 mile trip from Wales to the South of France,where I live.I've since done aproximately 1000 miles and it's got no worse. It makes a low vibration which can be felt through the steering wheel in 2-3 second pulses(if that makes sense).It only does it under power,ie,no vibration when coasting or in neuteral. I've checked the wheel bearings,props,CV joints and difs,all apears to be ok. So......Any ideas guys??? Thanks Marc. Quote Link to comment Share on other sites More sharing options...
PS_Bond Posted September 7, 2012 Share Posted September 7, 2012 Frequency sounds wrong for wheel balance, but have you checked it? Quote Link to comment Share on other sites More sharing options...
sharkey964 Posted September 7, 2012 Author Share Posted September 7, 2012 But surely,if it were wheels out of ballance,it would do it all the time,not just when the power is on. Plus,I would expect it to vibrate at certain speeds and not other's. Quote Link to comment Share on other sites More sharing options...
cypermethrin Posted September 7, 2012 Share Posted September 7, 2012 Remove the front prop and drive it..... I would guess there is some play in the diff which resonates at certain revs Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted September 7, 2012 Share Posted September 7, 2012 Is the front prop on the right way round, Early props have both propshaft sliders towards the front of the vehicle, later ones have the front prop the other way round, ie with the sliding section at the transfer box end. I had my 200Tdi prop on backwards and got exactly the same symptoms. Quote Link to comment Share on other sites More sharing options...
sharkey964 Posted September 7, 2012 Author Share Posted September 7, 2012 Is the front prop on the right way round, Early props have both propshaft sliders towards the front of the vehicle, later ones have the front prop the other way round, ie with the sliding section at the transfer box end. I had my 200Tdi prop on backwards and got exactly the same symptoms. It's a later one with the slider towards the rear. Quote Link to comment Share on other sites More sharing options...
rick Posted September 7, 2012 Share Posted September 7, 2012 Are the uni's in the front prop in or out of phase ? The uni's must be run out of phase as the diff pinion points up at the t/case. If someone has had the shaft out and reinstalled it with the uni's in phase you'll get vibration. Quote Link to comment Share on other sites More sharing options...
Steve King Posted September 7, 2012 Share Posted September 7, 2012 Is the handbrake OK?? Just a thought - if it was sticking on at all it might cause vibration. Quote Link to comment Share on other sites More sharing options...
Tibout Posted September 7, 2012 Share Posted September 7, 2012 uj's may be i've done all 4 on mine when i had vibration before Quote Link to comment Share on other sites More sharing options...
sharkey964 Posted June 30, 2013 Author Share Posted June 30, 2013 OK, A final update on this one..... After replacing just about everything. I changed the diff for another second hand one.Problem solved. I have inspected the one I took off and can't see any faults......But,hey ho. It's right now.:-))) Thanks for all your input on this one guys.It's much appreciated. Marc. Quote Link to comment Share on other sites More sharing options...
splandrovers Posted July 2, 2013 Share Posted July 2, 2013 Is there any chance abit of rubbish has got into the fuel Quote Link to comment Share on other sites More sharing options...
