Defender 110 spares
Hi everyone!
Finally bought my 110!!!
I want to buy all the spares from e-bay: 3 filter pack, break pads, belt, etc.
Can anyone suggest how may different belts there are and what else i should buy?
Also, what is the brand of the genuine parts and how can i recognize the genuine part on the e-bay?
Thanks a lot for your helps, guys!!!
I'll third the don't buy E bay.
I have two local motor factors I buy most of my spares from. Then I have an indi that I buy other things from. Not forgetting my Land Rover dealer where I buy my Land Rover Genuine Parts from
Being old fashioned I like to have in my hand what I'm buing before I part with what little cash I have
Almost all of the the suppliers mentioned above do free (or very cheap) next day delivery. Most online/mailorder suppliers suppliers will sell orginal, good OEM and cheap pattern parts so just make sure that your getting the right type. I think most people on here will agree that staying away from cheap pattern copies is a good idea - the good OEM parts are only a little more expensive than the pattern parts but a great deal cheaper than LR original. Can't speak for London suppliers but most non specialist average 4x4 garages (i.e. not Landrover specialists) tend to sell Britpart parts which if you trawl these forums is pretty much a no no - they apparently do some good parts but I've yet to find some. However you may have a local supplier that sells LR and OEM parts off the shelf which as mmgemini says is always nice but if you dont I'd stick to online/mail order.
If you've got a 300tdi then get a spare serpentine drive belt (they're pretty tough but always good to have a spare) note that these come in two lengths depending on basically the size of the alternator pulley. Ealrier 300tdis had a bigger puller and hence a longer belt whereas later versions or ones with A/C fitted a beefier alternator with a smaller pulley. Note as far as I am aware Dayco make this belt for Landrover and the Dayco OEM belt is much cheaper than the LR original which is assumedly exactly the same item just missing the green oval stamp so here's an example where OEM is the way forward. Somewhere on this forum I think someone has created a list of who some of the OEM suppliers for landrover are which is useful. For instance Denso make the alternators.
Most decent suppliers do complete service kits (i.e. filters) - many a debate on whats the best - just don't go for a cheap unheard of brand - Good brands do filters for pretty cheap so your not talking much difference to your wallet. Some people only use LR filters but I have always used Coopers filters.
I've only been on the forum for a couple of years - if you have any questions just ask here. Its full of legendary helpful advice and has come to my rescue numerous times.
Enjoy the 110 - I can't imagine life without mine anymore!
Over the years i've aquired/hoarded all sorts of the top of my head i've got:
Axle set of wheel bearings
Track rod ends
A frame ball joint
Oils
Oil, Air and Fuel filters
Nuts, bolts and washers.
Tons of gaskets (I buy gaskets around 6 at a time, there pennies)
Plus all the other bits that have either fell off and i've kept or thought would be handy from vehicles i've broke for parts
^^Same here, plus lots more*!!
Several sets of 10 and 11" brake shoes
Spare pair of 11" drums
Spare pair of 10" drums
Several spare instrument clusters
spare light lenses
spare light fittings
spare gearbox (currently needing rebuilding...usually have a rebuilt one on the shelf - must find time!)
*in truth, its mostly my project 109, which is currently dismantled and occupying lots of spaces!
Thanks a lot guys!
Is there a spares shop you can recommend in London where i can go personnally and get what i need? preferably near Harrow on the hill or near Hampstead?
Dingocroft are in High Wycombe which isn't *that* far from you - they are also very knowledgable, helpful (and patient!) if you aren't entirely sure what bits you need. They do sell some britpart though, but should have alternatives if you ask... http://www.dingocroft.co.uk/
