Bull Bar Cowboy Posted September 4, 2006 Share Posted September 4, 2006 Ah ………. I thought that would raise a smile or two………… However, no smiles here at the moment……… Having just replaced the valley gasket due to the gasket to rubber end-seals RTV letting go and dumping a litre of oil over the engine front cover in 600miles ………. firing up the engine after the repairs, I noted a ‘chuffing’ noise, and on the V8 that is typical of a leaking exhaust manifold gasket …….. so I didn’t pay a great deal of attention to it. Next day was a trip up the the M’way to Brizzle ……… on the way I noted the water temp was about 5/10 degrees above normal (as was the oil Temp) and the truck felt to be lacking a bit in the power department, but the journey was uneventful. The journey back was a different story ………. Intermittent misfire started and by the time I got to M5/J24 one bank of cylinders had handed in the towel ……. and it seemed to be really struggling on the remaining 4 (you will see why later…. read on). As I couldn’t detect the misfire on the REV counter then the lack of one bank had to be fuel ……… it occurred to me that I may have knocked the resistor pack wiring when fixing the valley gasket …… any fault here on the input will cause this problem as the injectors fire in 2 banks of 4. After 10mins on the hard shoulder trying not to get killed …….. the AFM was removed and the resistor pack connector reseated ………. Once back together, all was well with the V8 heartbeat …………apart from the water temp being 100C @ 2600rpm (70mph), lack of power, …….. and I could hear the ‘chuffing’ noise. Saturday morning was spent with the diagnostics hat on ………. ‘chuffing’ appeared to be coming from ‘engine central’ rather than the manifolds ………. removing the oil filler and breathers revealed a good impression of puffing billy …….. but this was exhaust gas and not steam. A compression check told me all I needed to know ……… Right Bank, 2 = 180+ 4 = 180+ 6 = 180 8 = 180+ Left Bank 1 = 180 3 = 180+ 5 = 90 7 = 145 So, it looks like 5 has blown into the valley and also into 7 …….. that would explain why the valley gasket gave up …………. Head will come off tonight and I am hoping its nothing anymore serious than the gasket ……… the only other option is a holed piston ........... but that is usually accompanied with clouds smoke from burning oil. I am really beginning to think Diesel is the way forward……… I keep records (yes, I know, its sad)……… and the history is not good, Looking at it since the ‘attention to detail’ rebuild, 15K = both Tin head gaskets changed to composites due to the coolant smelling like an exhaust pipe. 32K = Right hand bank head gasket replaced due to blow between 4 & 6 …….. caused by a head centre row bolt letting go on the ali block threads 42K = this is where we are now ………. Another bloody head gasket ……. Left hand bank this time. Other stuff, 8K = valley gasket ……… coolant leak 23K = Valley Gasket ……. Coolant & oil leak 42K = Valley Gasket ………. Oil leak I am slowly beginning to lose my patience (I suppose I am becoming an old git now) with the V8……… it was probably good as a Buick until they let loose the Rover and Lucas crowd on it. I’ll keep you guys posted when I lift the head tonight …………….. Ian Quote Link to comment Share on other sites More sharing options...
jules Posted September 4, 2006 Share Posted September 4, 2006 I remember when Read90 was changing rear mains and head gaskits on his 90 2.5 N/A for a past time I think it was 4gaskets and 3 rear mains before he discovered that the new rings on the first fitting and not beded in properly and the crank pressure was blowing the rear mains and not the head. I would say its time for a new or recon enging there is somthing amiss with your lump that list of faults I would have binned it long ago.. but I have been there with trucks before... some times it's not better the devil you know. Don't go to the smoky side no matter how tempting Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 4, 2006 Share Posted September 4, 2006 As far as I can tell the only difference with TDi's is that they run better in water - listening to the chat at club meets the TDi's are not really any more reliable than V8's, and the parts seem to be more pricey because the world and his dog want TDi's for some reason. Yours seems mostly down to carp gaskets, which is not really a major expense even if it is a PITA. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted September 4, 2006 Share Posted September 4, 2006 parts seem to be more pricey Ah, but we've got £20 back every time you visit the fuel station, so we can afford blingy injector pumps etc. Go diesel Ian - once it's started, it's running. Quote Link to comment Share on other sites More sharing options...
jules Posted September 4, 2006 Share Posted September 4, 2006 Ah, but we've got £20 back every time you visit the fuel station, so we can afford blingy injector pumps etc. Go diesel Ian - once it's started, it's running. (and the rest) But when a V8 stops it can be bodged into life to get you home but a diesel when it stops, its over Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted September 4, 2006 Author Share Posted September 4, 2006 Interesting……………………………… I suppose I had better explain a bit more about the engine ………its was far from a standard rebuild…………. HC pistons and the block decked to match the pistons (3.5+20) & fitted with Clevite ‘Buick’ rings ………. Reground crank fitted with Clevite ‘Buick race shells’ ..... ARP Studs…….. new cam bearings ……… 3.9+ cam ……. Heads ported and polished and skimmed …… all new top end ……….. even down to the rocker posts………… cloyes timing gear …… etc, etc. The head gaskets I use are ‘Real Steel Composites as they are the only suppler I know of that produces them especially for the 3.5 and includes the outer row bolt holes. As a point of interest, I only fit the outer row to fill the holes (and hold ancillaries) but they are only lightly torqued to less than 20ft/lb. I know that the TVR crowd fit LR 3.9 compo gaskets to the 3.5’s and leave out the outer row bolts (no holes) ………. but to me, that is a bodge due the difference in bore sizes ……. however, they tell me that it works fine ….. (I don’t know their definition of ‘fine’ though). Ian Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 4, 2006 Share Posted September 4, 2006 Plus a V8 will run on half the cylinders - and still sound better to boot Seriously though - could it be there's a problem with eitehr the heads or the top of the block not being flat that's causing it to eat gaskets? I don't know the specs of the lump but I'm guessing it's well built. (Edit: D'Oh! Just as I post this you post your specs!) Oh and is this the 5-minute argument or the full half hour? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 4, 2006 Share Posted September 4, 2006 split the odds John and go for 10 mins? japanese diesel.... tin hat time (again ) Quote Link to comment Share on other sites More sharing options...
Daan Posted September 4, 2006 Share Posted September 4, 2006 Driving to scotland (from oxford) took 60 litres of fuel. competing in argyll took about 15 litres of fuel per day(okay not many stages...). Its a bogstandard 300 TDI I use. Try that in a V8. I hear of problems with both engines, but I believe a fresh engine should last 100000 miles without this kind of trouble. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted September 4, 2006 Share Posted September 4, 2006 I'm just joshing about V8s (although they are terribly susceptible to a misty day and seem to consume as much WD40 as anything else...) Ian - could there be an inertial problem with any ancillaries? If you've got anything special bolted to the heads (on your outer row of bolts?) then any vibrations might be distorting the head face out of flat when the lump's running? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 4, 2006 Share Posted September 4, 2006 Quote Link to comment Share on other sites More sharing options...
jules Posted September 4, 2006 Share Posted September 4, 2006 japanese diesel....tin hat time (again ) Don't mention 2.8's you'll get Will started Quote Link to comment Share on other sites More sharing options...
jules Posted September 4, 2006 Share Posted September 4, 2006 japanese diesel....tin hat time (again ) Joking aside Has anyone ever put a 4.2 land cruser toyota lump in a rover.. Bet thats got some grunt in it Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 4, 2006 Share Posted September 4, 2006 Bloody heavy Jules - Nissan SD35's go in well, just as much horse and torque as a TLC lump and a lot easier and cheaper to fit (and get hold of in the first place) Quote Link to comment Share on other sites More sharing options...
jules Posted September 4, 2006 Share Posted September 4, 2006 Bloody heavy Jules - Nissan SD35's go in well, just as much horse and torque as a TLC lump and a lot easier and cheaper to fit (and get hold of in the first place) Was it the Nissan or Mazda RRC convertion which were popular before the days of cheap Tdi's I have a mate that was a V8 man through and through until he drove a Mazda and loved it for it's power.. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 4, 2006 Share Posted September 4, 2006 Both, Mazda SLT was another stonking motor - the only drawbacks with them was the weight and the length, on a rangie you have to move the front crossmember forward 100mm to clear it all Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted September 5, 2006 Share Posted September 5, 2006 I think if one was to gather statistics and compared the ''whole of life'' running costs of a Rover V8 vs a Rover TDI, there would be very little difference, and may actually favor the V8. Japanese Diesels have earned their well deserved reputation for dependability in the tough gruelling highly competitive world of day to day commercial vehicle operation around the world.I have had a normally aspirated Toyota 3B 3 litre deisel sitting in my shed for a few years, just waiting for my much abused and long suffering 2 1/4 litre petrol engine to cry enough.The Toyota engine gave great economy in the old BJ40 donor vehicle that I drove for a few months.Horsepower and torque were adequate for sensible non competition use, and performance is consistant because it doesn't have any delicate timing belts, turbo charger or intercooler to fill up with mud and become ineffective. IMO Rover built diesels are an expensive liability I just cannot afford to have go wrong in harsh conditions a couple of hundred miles from any hope of assistance. Bill. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted September 5, 2006 Share Posted September 5, 2006 I don't agree with the v8-tdi reliability thing. me and Rog (898kor) have a joint spares box for our offroading, it contans for his v8; plugs, leads, dizzy cap, rotor arm, luminition module, fuel filter, fuel pump and a multimeter . All of which have seen use over the years. And for my 300tdi we carry a fan belt, which i have actually used once. V8's are reliant on too many systems. As long as you can get fuel to a tdi it will run. Plus v8's are getting a little long in the tooth, try finding a decent front cover these days, or even worse a good set of su's. Quote Link to comment Share on other sites More sharing options...
pugwash Posted September 5, 2006 Share Posted September 5, 2006 try finding a decent front cover these days, or even worse a good set of su's. yeah i got a mint serpentine front cover- £22 Su? WTF are those for? only reliable thing for a V8 is megasquirt Quote Link to comment Share on other sites More sharing options...
trainspotter Posted September 5, 2006 Share Posted September 5, 2006 I had a V8 once and it was nothing but F---ing trouble and broke down all the time. A real pile of S--t. I had it for 4 months. Which was 4 months too long believe me. Yes, if you have one thats brand new or one thats been refurbished by a reputable company, they might sound nice but they soon start to cause problems and the fuel consumption is terrible. Also when it did run it didn't seem to be any faster or more powerful than the 200 tdi in terms of general road use. AS FOR JULES SAYING YOU CAN BODGE IT UP TO GET HOME WELL WHY DON'T YOU JUST DO WHAT I DO AND JUST DRIVE HOME INSTEAD WITHOUT BREAKING DOWN ETC. THATS A NOVEL F---ING IDEA!!!!!!!!! BIN THE BLOODY THING I've had a Disco 200tdi for 5 and a 1/2 years and it's never ever failed to start. I check everything thoroughly once a month and change the oil every 3k and thats it. END OF STORY BUY A 200TDI. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted September 5, 2006 Share Posted September 5, 2006 yeah i got a mint serpentine front cover- £22Su? WTF are those for? only reliable thing for a V8 is megasquirt Would that be a mint serp front cover with a dizzy hole in it so it's at least nearly fixable. Megasquirt is only reliable untill you drown the ecu, then your going home on a rope. Su's and a points type dizzy and you might be able to get it going again, The only problem with all these electronics is they cannot be fixed in the field. Quote Link to comment Share on other sites More sharing options...
jules Posted September 5, 2006 Share Posted September 5, 2006 I had a V8 once and it was nothing but F---ing trouble and broke down all the time.A real pile of S--t. I had it for 4 months. Which was 4 months too long believe me. Yes, if you have one thats brand new or one thats been refurbished by a reputable company, they might sound nice but they soon start to cause problems and the fuel consumption is terrible. Also when it did run it didn't seem to be any faster or more powerful than the 200 tdi in terms of general road use. AS FOR JULES SAYING YOU CAN BODGE IT UP TO GET HOME WELL WHY DON'T YOU JUST DO WHAT I DO AND JUST DRIVE HOME INSTEAD WITHOUT BREAKING DOWN ETC. THATS A NOVEL F---ING IDEA!!!!!!!!! BIN THE BLOODY THING I've had a Disco 200tdi for 5 and a 1/2 years and it's never ever failed to start. I check everything thoroughly once a month and change the oil every 3k and thats it. END OF STORY BUY A 200TDI. Easy tiger no need to shout Every day (38k per yr) I use a Td5 disco I have a brother he loves Diesel & I love V8 Over the past 12 years he has replaced / rebilt 2.5 NA x heads off 4 times 2 new sets of rings 1 x complete rebuild 2.5 tdi one needed new block and rebuild three cam belts haves snaped each one lasted less than 10k Me all in the same 90 Given V8 3.5 efi after 5 years lost oil pressure ( would have helped if I changed the oil ever) I then drove to distruction so I could get home still got me the 35m home. I replaced it with a 55,000mile 4.2 V8 given nothing but complete abuse never missed a beat over the last three or four years Simple.... Quote Link to comment Share on other sites More sharing options...
Daan Posted September 5, 2006 Share Posted September 5, 2006 I think if one was to gather statistics and compared the ''whole of life'' running costs of a Rover V8 vs a Rover TDI, there would be very little difference, and may actually favor the V8. I have to disagree here. In your part of the world the landrover diesel engine might be expensive, but here its the way forward. a conversion set for a japanese diesel is usually more expensive than the engine. So most people go for the landrover option. It cuts fuel bills in halve compared to a v8 and with fuelprices for diesel and petrol about £1 a litre, that is a big difference. Quote Link to comment Share on other sites More sharing options...
sgnas Posted September 5, 2006 Share Posted September 5, 2006 But that is just classic Land Rover One gets treated with kidd gloves, all the best parts, best oils, weekly checks - breaks down at every oportunity. Whereas the farm hack, held together with baler twine, run on god knows what fuel, never had the oil changed - runs and runs until the day it collapses in a cloud of iron oxide Quote Link to comment Share on other sites More sharing options...
Andy Posted September 5, 2006 Share Posted September 5, 2006 from experience with my tdi & few mates with petrol lumps. id say the V8 needs more fiddling but dies about as often as a Tdi. my Tdi loves to eat cambelts, ive had it 4 years now & they snap every 15k or so. ive replaced everything & know i built it right, just seems allergic to the damn things. i love the sound of a V8 but i wouldnt get one as it takes way too much effort to make them waterproof. plus i just dont like electrical stuff offroad, it goes wrong to often on me. Quote Link to comment Share on other sites More sharing options...
