chris200100 Posted September 22, 2012 Share Posted September 22, 2012 I need to remove my steering wheel to replace the switches behind it and the thing is stuck well and proper, I've tried everything to remove it and it won't budge. Any suggestions Chris Quote Link to comment Share on other sites More sharing options...
mmgemini Posted September 22, 2012 Share Posted September 22, 2012 Which switches ? I don't remember removing my steering wheel when I replaced the dip switch or moved the rear fog switch up to the column. Have you got the nut undone ? Then leave the nut on a few threads. Get hold of the wheel and struggle with it. Also you can belt it from underneath with a soft faced hammer. Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted September 22, 2012 Share Posted September 22, 2012 I had to hit the back of my wheel to lossen it then pull it but as said make sure you keep a couple turns on the next else you end up with a sore nose where the steering wheel hit it. Quote Link to comment Share on other sites More sharing options...
chris200100 Posted September 22, 2012 Author Share Posted September 22, 2012 I've got it off now thanks, it took some going too. I tried the hammer no joy. In the end it took heating it up with a blow torch and a hub puller and then it didn't pop off took some doing. Quote Link to comment Share on other sites More sharing options...
RILEY Posted September 22, 2012 Share Posted September 22, 2012 Hi mate for the future wind the nut to the top one swift hammer blow on the nut and Robert is your mothers brother ! Quote Link to comment Share on other sites More sharing options...
western Posted September 22, 2012 Share Posted September 22, 2012 or be a bit less brutal & make up a puller with suitable fully threaded bolts & a block of steel. Quote Link to comment Share on other sites More sharing options...
KennyC Posted September 23, 2012 Share Posted September 23, 2012 Slight hi-jack now this tread is almost finished...my 1989 bitza has this steering wheel fitted ( Landy still getting a new gearbox so can't provide a better photo )....how is my particular steering wheel removed ? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2012 Share Posted September 23, 2012 prise the badge from centre & you'll see the nut, undo this but don't take it fully off, use a puller or the methods mentioned above, the wheel will come off the splines to the nut, then remove the nut fully & lift wheel off the column. Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted September 23, 2012 Share Posted September 23, 2012 I use a puller, there should already be two tapped holes in the wheel to bolt it to, tighten the big bolt and off it comes. Quote Link to comment Share on other sites More sharing options...
Smego Posted September 23, 2012 Share Posted September 23, 2012 Never managed to budge mine, gave up in the end... Quote Link to comment Share on other sites More sharing options...
KennyC Posted September 24, 2012 Share Posted September 24, 2012 Thanks guys, appreciated :-) Quote Link to comment Share on other sites More sharing options...
