ANTOINE Posted November 5, 2012 Share Posted November 5, 2012 Hi, just a question how many volt with EDIS and MS a DUI distributor give 50 000 volt to the coils, so how many edis ?? thanks Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 5, 2012 Share Posted November 5, 2012 The ford G1 cool packs pop out 40000+ volts It's not the Edis Nige Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 5, 2012 Share Posted November 5, 2012 "cool packs" - do those need 24 hours in the freezer before use? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 5, 2012 Share Posted November 5, 2012 Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 5, 2012 Share Posted November 5, 2012 Summit racing sell uprated coil packs but honestly, EDIS with standard coils is quite enough for anyone... Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted November 6, 2012 Author Share Posted November 6, 2012 ok, thank you, nobody know voltage exately , just for the info Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 6, 2012 Share Posted November 6, 2012 I also know the hard way ........... On rover v8s with misfires I would plug leads off and see if a difference, then hold plug cap near plug sometimes the spark would show so knew that cyl ok, somtimes nothing = cyl with fault There was a mate with MS'd V8 - and it had a misfire I did my "pull lead off and see if spark jumped trick", it did, ....all 40,000volts of it did, about a 2.5" "Jump" spark The pain was intense, as was my squeal, mate next to me guessed my jump was a clear 10-12" and I also went grey hand was numb up to shoulder socket, and I felt sick. I nobbled off having dropped everything on the floor where I had been standing and went at sat in a warm corner saying "****" I remember sitting in the corner, for some time, listening to the guffaws sniggers and "Re enactments" from "Mates" and it was a good 10 mins before I was able to chase the worst "Mate" and give him a 'Dead Arm' being the grown up person I am NEVER EVER AGAIN will I "Play" with G1 Coil Packs ! Nige Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 6, 2012 Share Posted November 6, 2012 One can work it out from that photo. Air breaks down at about 30 kV/cm, that gap between the plugs is at least 15 mm, so we can say at least 45 kV. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 6, 2012 Share Posted November 6, 2012 One can work it out from that photo. Air breaks down at about 30 kV/cm, that gap between the plugs is at least 15 mm, so we can say at least 45 kV. Is that the case? In the picture I can't see an earth, I would guess (but am probably completely wrong) that the coils must be centre tap earthed for that to work so the effective voltage being applied in the picture would be double that normally applied. In fairness I know nothing about V8's or how the coils/edis are wired so am very likely to be talking out of my backside Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 6, 2012 Share Posted November 6, 2012 The short version - it doesn't matter, the sparks are much much better than the standard Rover ignition and more than enough for anything this side of top fuel drag racing. Quote Link to comment Share on other sites More sharing options...
