4.11 Diff Ratios
4:11 was developed to give you same gear ratios as a standard 90 or 110 fitted with 235/85x16 0r 750/16 fitted with a standard transfer box
WHEN using 35' tyres.
So thats your answer....35'
However you can go up a bit, as the it does leave the vehicle with a fairly low top end, 65 to 70mph :(
Hope that clears things up a bit for you :)
Jim :)
Guest diesel_jim
On my 90 (300Tdi) i used to have 4.1:1 diffs, 1.2:1 transfer box and 35" simex's. it drove almost like stock gearing, if anything, everyso slightly lower (but only a bit)
i'm running std diffs with 1.4T box and 35s.
therefore although 4.1 were for 35" tyres you could prob go a bit bigger.
depends what you want, large tyres and low engine revs at high speed (therefore need more bhp/Nm to get there) or large tyres for offroading but maintaining a low low speed for winching/decents.
