porsche Posted March 14, 2013 Share Posted March 14, 2013 fitting new DENSO alternator today , can someone give me an idiot guid to which wires and colours go where , seemed to have burnt a little wire on old one before the bearings gave up the ghost !!! the new one has bolt connections and not spade , it`s an uprated 100 amp for 8274 . many thanks . Quote Link to comment Share on other sites More sharing options...
western Posted March 14, 2013 Share Posted March 14, 2013 this should help. Quote Link to comment Share on other sites More sharing options...
porsche Posted March 14, 2013 Author Share Posted March 14, 2013 my new one has 3 studs and a male connection off one of the studs !! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 14, 2013 Share Posted March 14, 2013 my new one has 3 studs and a male connection off one of the studs !! A pic will help. Its most likely the small brown wire goes on the stud with a terminal and you'll then have a stud marked B+, this runs the charge cable to the starter/battery... You'll need 16mm cable minimum for this new alt. Quote Link to comment Share on other sites More sharing options...
porsche Posted March 14, 2013 Author Share Posted March 14, 2013 ok , will take a pic Quote Link to comment Share on other sites More sharing options...
porsche Posted March 15, 2013 Author Share Posted March 15, 2013 said alternator Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 15, 2013 Share Posted March 15, 2013 The 'W' terminal will be for the rev counter, so unless you have one, you don't need it Quote Link to comment Share on other sites More sharing options...
SPendrey Posted March 15, 2013 Share Posted March 15, 2013 The rev counter for the W terminal? That's interesting. My counter has been dropping to zero and then back up to wherever it was on a few occasions recently, and then I believe the alternator failed because I was getting 14.4V, then I wasn't, then I was again, and then I got >20v! So, I decided replace it. However, I hadn't thought the rev counter and the alternator issues perhaps being connected? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 15, 2013 Share Posted March 15, 2013 Cant really make out the terminals, the image is a bit small. I can see D+ and maybe M or W, but i dont see the main B+ terminal? Quote Link to comment Share on other sites More sharing options...
