scottwilson1912 Posted March 14, 2013 Share Posted March 14, 2013 Hello all So im in the process of trying to remove my front prop, as the U/J is badly worn...So i had a nose under there and managed to remove 3 of the nuts but the rest look like they have been on there for ever and no amount of spannering will shift them, Now if i cut the front bolts of with a grinder they can be replaced easy enough but the transfer box end the bolts are captive in the flange, 2 of these bolts are rounded off and need replacing but how do i get new ones through the back of the flange to go through the prop??.....Help Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted March 14, 2013 Share Posted March 14, 2013 Once you have cut thee bolts off and got the prop off, you will have to undo and remove the flange to change the bolts. I would chage the oil seal while you have it off too. Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 18, 2013 Share Posted March 18, 2013 You should be able to get a hydraulic nut breaker to fit and split the nuts without damaging the bolt. Quote Link to comment Share on other sites More sharing options...
scottwilson1912 Posted March 19, 2013 Author Share Posted March 19, 2013 Soaked them all in WD40 over night and when i put the right spanner on them 9/16th NOT 14mm managed to get them all out....Doh Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 23, 2013 Share Posted March 23, 2013 You should be able to get a hydraulic nut breaker to fit and split the nuts without damaging the bolt. I've always wanted on of those, might get one for this new truck, think i might need one! Quote Link to comment Share on other sites More sharing options...
gadget Posted March 27, 2013 Share Posted March 27, 2013 I've always wanted on of those, might get one for this new truck, think i might need one! I've got the cheap manual nut splitter and used it today to remove a stubborn castle nut. Wonderful devices Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 27, 2013 Share Posted March 27, 2013 Soaked them all in WD40 over night and when i put the right spanner on them 9/16th NOT 14mm managed to get them all out....Doh 14mm is a tighter fit than 9/16, so shouldn't have been rounding for that reason. There's a Difflock propshaft tool', do a google, makes changing props a doddle, even with rounded nuts. Quote Link to comment Share on other sites More sharing options...
