henk Posted June 11, 2013 Share Posted June 11, 2013 My project:: a Series body with 200tdi on a shortened RRC chassis with late D1 axles. So the brake problem has been solved, I fitted the brake booster of a Defender and remade all the brakelines and am now moving towards the body but: Due to the huge brake servo and the different steering, the Series wings do not fit at all so I opted for Defender wings but if I also fit the Defender bonnet I loose the Series look so how could I solve that? Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted June 11, 2013 Share Posted June 11, 2013 fit remote brake servo? (its what i plan to do but with the clutch ) Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2013 Share Posted June 11, 2013 or cut the Series wing to allow it to fit around the brake servo, 90/110 have seperate inner wing/arches. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted June 11, 2013 Share Posted June 11, 2013 Series wings do not fit at all so I opted for Defender wings but if I also fit the Defender bonnet I loose the Series look Option A: Use Defender bonnet with stage one grille Option B: Use series bonnet with front extensión, as in Santana Cazorla/Six cylinder Option C: Use rear extensión for series bonnet, as seen in Santana Militar with straight six Quote Link to comment Share on other sites More sharing options...
Gremlin Posted June 12, 2013 Share Posted June 12, 2013 Have a look at my build, defender servo with series wings (modified) defender inner arches and series bonnet. G Quote Link to comment Share on other sites More sharing options...
henk Posted June 12, 2013 Author Share Posted June 12, 2013 @Gremlin: As far as I can see on pictures posted on 18/9, you kept the outside and upper part of the series wing and removed all the rest and then fitted the inner arch of a Defender wing? Quote Link to comment Share on other sites More sharing options...
Gremlin Posted June 12, 2013 Share Posted June 12, 2013 Yes exactly. G Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 12, 2013 Share Posted June 12, 2013 Fit *early* defender (or Range Rover) servo, make small cut to wing, sorted. Quote Link to comment Share on other sites More sharing options...
