dirtyninety Posted June 16, 2013 Share Posted June 16, 2013 As in the title, what thread bolts are used to mount mile marker h12 winches. Seems it must be an American imperial thead! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 16, 2013 Share Posted June 16, 2013 Is this any use? http://milemarker.com/pdf_downloads/75series_instruction.pdf Might be able to decode the numbers. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 16, 2013 Share Posted June 16, 2013 Attach winch to winch-mount tray by screwing 4 bolts (C-3/8 X 16 X 1 SS Hex Head Bolt) and washers (D-3/8 SS Washer) through the pre-drilled holes in bottom of winch mount tray into bottom of winch body. Tighten to 35 ft/lbs. Make sure that you have AT LEAST 6 threads going into the winch legs, but NO MORE THAN 10 threads going into winch leg. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 16, 2013 Share Posted June 16, 2013 Thats 3/8"UNC. BSW should fit but as the thread profile angle is 5* different its not good practice. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted June 16, 2013 Author Share Posted June 16, 2013 Cheers, thankyou very much! I couldn't see that for looking on the milemarker website!! Quote Link to comment Share on other sites More sharing options...
mikec Posted June 16, 2013 Share Posted June 16, 2013 Oh that's saved me asking the same question Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted June 16, 2013 Share Posted June 16, 2013 I'd be looking at helicoiling them out to something easier to find in the field like m10x1.5 Quote Link to comment Share on other sites More sharing options...
mikec Posted June 16, 2013 Share Posted June 16, 2013 Mine are helicoiled anyway is that standard? Quote Link to comment Share on other sites More sharing options...
zim Posted June 20, 2013 Share Posted June 20, 2013 I'd be looking at helicoiling them out to something easier to find in the field like m10x1.5 The aluminium housing version come helicoiled from factory 3/8 UNC as said above. Not difficult to find. G Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 21, 2013 Share Posted June 21, 2013 Ahem. A British Imperial thread copied (like everything) by the Americans who are now the only ones to use it due to the fact the British have sold their soul to the European metric devil Quote Link to comment Share on other sites More sharing options...
mikec Posted June 22, 2013 Share Posted June 22, 2013 Slightly off topic, but does the mm use the fairlead holes a load bearing fixings? Reason I ask is there's a reasonable gap between front of the winch and my new bumper. Are the four bottom bolts enough to hold it? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 22, 2013 Share Posted June 22, 2013 Only the four holes in the bottom AFAIK. Same as most low-line winches Quote Link to comment Share on other sites More sharing options...
mikec Posted June 22, 2013 Share Posted June 22, 2013 Ah ok, I've only really had huskies before. Cheers again Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 22, 2013 Share Posted June 22, 2013 Ah ok, I've only really had huskies before. Cheers again The Husky needs the extra fixings for support due to the fact that it weighs as much as a small moon Quote Link to comment Share on other sites More sharing options...
mikec Posted June 22, 2013 Share Posted June 22, 2013 The Husky needs the extra fixings for support due to the fact that it weighs as much as a small moon Haha maybe so, to be honest I prefer the idea of the front bolts holding it too, might modify this bumper, belt and braces and all Quote Link to comment Share on other sites More sharing options...
zim Posted June 23, 2013 Share Posted June 23, 2013 Mike, I bolt mine downwards. Trust me in saying they're fine like this. We've used them heavily for a few years now. G Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 23, 2013 Share Posted June 23, 2013 They are designed to bolt feet down Mike Quote Link to comment Share on other sites More sharing options...
mikec Posted June 23, 2013 Share Posted June 23, 2013 Haha cheers guys Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 23, 2013 Share Posted June 23, 2013 If you're not careful, you'll end up like Nige, and have a bumper that would make a suitable anchor for the worlds largest ship Quote Link to comment Share on other sites More sharing options...
mikec Posted June 23, 2013 Share Posted June 23, 2013 Yeah, I do like to add my little "improvements"! Haha Quote Link to comment Share on other sites More sharing options...
