muss12 Posted June 21, 2013 Share Posted June 21, 2013 Get back to the 90 after work to find a nice oil patch underneath, drove home left it for 45 mins and another nice patch! Can't see where it's coming from but there's oil sat on top of the diff in the grove. Any pointers where I can start for tomorrow's adventure covered in the black stuff Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 21, 2013 Share Posted June 21, 2013 I'm assuming front diff? As there's not really anything that can leak oil above the rear one. Most likely engine oil or perhaps PAS fluid. Checked the levels on either recently? Put a bit of card/paper over the diff and see what collects and what colour/type of oil it is. Quote Link to comment Share on other sites More sharing options...
muss12 Posted June 21, 2013 Author Share Posted June 21, 2013 It's defo engine oil but can't for the hell of me see where it's all coming from, could it be from the seal on the sump? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 21, 2013 Share Posted June 21, 2013 Could be. Or from the front crank seal and dribbling out of the hole in the bottom of the timing chest. Or from one of many other places higher up then running down the side of the engine. I had a leak on my 200Tdi for years that I thought was the sump but turned out to be the rocker cover half-moon gasket at the rear. Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted June 21, 2013 Share Posted June 21, 2013 i would be looking at the oil filter make sure its tight Quote Link to comment Share on other sites More sharing options...
muss12 Posted June 21, 2013 Author Share Posted June 21, 2013 Thanks for the replies I'll start from the sump and work my way up Quote Link to comment Share on other sites More sharing options...
jbs Posted June 21, 2013 Share Posted June 21, 2013 I'd also check if your dipstick is firmly in place-i.e.: all the way home as this will leak oil if not fully fitted and may have dribbled down the block and then onto the diff/axle John Quote Link to comment Share on other sites More sharing options...
bluehaze Posted June 21, 2013 Share Posted June 21, 2013 If it's a 200 check the state of your air filter in case oil is moving through it and dripping out of the grommet. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 22, 2013 Share Posted June 22, 2013 i would be looking at the oil filter make sure its tight If it's a 300 Tdi, then this is almost certainly the source. There is a slim chance that the gasket between filter housing and block has failed, and a fair possibility that the oil cooler hoses have loose joints, but a loose oil filter is the first thing to look at. Quote Link to comment Share on other sites More sharing options...
muss12 Posted June 22, 2013 Author Share Posted June 22, 2013 Thanks for all your input, pulled up at my garage and got my ramps out and oil already on the floor! Cleaned everything off and can't see where it's coming from???? Sump bolts are loose so took that off and re sealed all of that, but to me it's coming from the oil filter side because of the oil on the front diff, it is a 300tdi Oil filter is tight- so going to put oil back in lay underneath and start her up and hopefully she will show me where it's coming from Quote Link to comment Share on other sites More sharing options...
cluffy Posted June 22, 2013 Share Posted June 22, 2013 Perhaps oil filter housing. I had a leak on my old 200 where someone replaced the housing with a new one and sealed it up with some crappie sealant! Quote Link to comment Share on other sites More sharing options...
muss12 Posted June 22, 2013 Author Share Posted June 22, 2013 Update, I really would rather not say what the problem was in the end lol What a t#%t! After taking off clean and re placing everything oil like it was a desial leak! All I'll say is my engine is nice and clean! And I really shouldn't own a landrover! Thanks for the help guys Jim Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 22, 2013 Share Posted June 22, 2013 Well at least you found it Anyway all the oil being washed off the engine and years of spilled oil from filter changes getting washed out of the diff casting could make it seem like an engine oil leak. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 24, 2013 Share Posted June 24, 2013 Split injector leak off pipes, by any chance? Those thin braided hoses perish in no time and tiddle diesel everywhere... Quote Link to comment Share on other sites More sharing options...
muss12 Posted June 26, 2013 Author Share Posted June 26, 2013 Yes thats the ones, but I had the Injectors changed by a very well known landrover place and they slit the ends to put them back on instead of changing them! Quote Link to comment Share on other sites More sharing options...
